Old 11-29-2010, 09:12 AM   #1
Bedroom Slide Does not want to extend out
We have a Cedar Creek Daydreamer with 3 slides. The bedroom slide always needs a push from inside to enable it to go out. Coming in works just fine with no assistance needed. Can it be adjusted or is a repair needed?
Where do you access the motor it you wanted to inspect it?
Don C is offline   Reply With Quote
Old 11-29-2010, 11:45 AM   #2
Does it make any noise or movement at all when you push the button to extend the slide? If not, you most likely have a bad or dirty contact switch. The motors for the slides are under the slide rooms, but since it works coming in with no problems, I'd focus on the switch being the culprit. Good Luck, Randy
Old 11-29-2010, 05:32 PM   #3
Randy, thanks for the response.
The noise when we hit the button is the normal sound, and the slide does move. It just seems to stick in place, the bottom comes out and the top seems to be stuck. When we push from inside, it seems to hit a bump and then continue out. I hear no unusual noises. All three slides operate from the same switch and the others operate as they are supposed to.
Old 09-17-2012, 09:47 AM   #4
We are experiencing the same issue. Do you find a solution?
ZanMan4U is offline   Reply With Quote
bed, bedroom slide
