Old 08-26-2019, 11:25 AM   #1
CWW
Question Bedroom slide out not working
HELP please. I have a 2010 FR sunseeker 3120 33' long. The bedroom slide just started not to work, one side will start to go out but the other side will not got out at all. It starts to jam so I stop it and bring it back in. How does all of this work? any videos on how it all works? How to fix? or do I just give up?
HELP PLEASE?
CWW is offline   Reply With Quote
Old 08-26-2019, 12:35 PM   #2
bikendan's Avatar
What type of slideout do you have?
Equalizer WDH
Old 08-26-2019, 02:19 PM   #3
CWW
It has aluminum geared runners (2) on each side that I can see when it is out.
Old 08-26-2019, 02:38 PM   #4
Just as confused as you
Scrapper's Avatar
You have a Schwintek slide.
File Type: pdf Schwintek-Slide-Troubleshooting-Guide.pdf (2.65 MB, 55 views)
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 08-26-2019, 02:41 PM   #5
bikendan's Avatar
Yep, Schwintek system.
Go to YouTube for numerous troubleshooting videos.
Equalizer WDH
Old 09-01-2019, 11:50 PM   #6
CWW
Angry HELP
Well I went out and tried to move the slide out and it stop, then I tried one more time and left side bumped a little and started to go out. I did this one more time and the same thing. So it works a little, but I can't see anything as it is less than 6" from the slide to the wall on both sides.
Old 09-01-2019, 11:52 PM   #7
CWW
Help
I am in the Reno area if there is any help around here...?????
Old 09-02-2019, 07:49 AM   #8
DaGrinch's Avatar
Find your controller.... it should be under the bed. It's a 4"x6"x1" box. Do you have a hinged piece of plywood under your mattress? If so, lift up the plywood. If you see another piece of plywood screwed down, look under it. That's where I found my controller. Should be lights blinking if you find it.
Yep, YouTube is your friend. Should give you an idea.
Larry
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 09-02-2019, 11:59 AM   #9
CWW
So I have two cans of lube can I use the red one?
Old 09-09-2019, 10:35 AM   #10
CWW
Larry
No lights blinking at all...
bed, bedroom slide, roo, slide, slide out
