Bedroom Slide Stuck Out
New to RVing and posting so please forgive me if this has been covered but could not locate.
2014 FR Georgetown 328TS. Bedroom slide would stopped working in the extended position. There was a loop of the cable showing inside the MH in the upper left of the slide.
Checked fuses, all good but swapped them around to make sure, all okay.
Finally after a week of searching websites and forums and finding no help I started searching on my own, Finally found the location of the motor, electrical and gearing. If anyone else is having a problem, they are behind the decorative board above the slide. Remove the screw covers at each end and use a square bit to remove the screws.
Two cables disconnected from lower control of the slide, one from each end of the chain. One bolt lost the nut the was holding it in place, the other bolt snapped. With only one cable in each bracket it turned 90 degrees which then caught on electrical cable and separated the cable joints. Plugged them back together and had power again. My helper (my lovely and helpful bride) pressed the switch to bring the slide in about two inches as a test. This allowed me to get the loop of cable back in the box.
At least now I know I can get the slide in for my upcoming trip and then I can take it to someone to get it repaired. Saved a Mobile Tech call and cost.
Hope this helps someone who may have the same problem.
