08-24-2014, 01:24 PM
Before anything happens .......pics, how to put slide in?
I will be heading out in few days for a week. My slide workS fine, but out of curiosity, how do I put it in after it fails to retract. my trailer is two years old and I'm not worried, but don't want to browse the forums when it gets stuck out.
08-24-2014, 01:26 PM
08-24-2014, 02:03 PM
I believe that's a schwintech mechanism. Unless you have an opening for a hand crank on the opposite side, I think the correct way is to disconnect power to the site motor, physically push the slide in, then reapply power. I may be wrong though, so others will chime in
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
08-24-2014, 02:06 PM
no opening , but yes pull power or remove/loosen motor screws and lift motor out of the way then push the slide in, you tube is your friend on how to do this
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
08-24-2014, 03:26 PM
Mine has a small panel held in place with a couple screws. The crank access is inside.
Brian and his Girl Crew
5 bikes - one top tube
Rig: 2004 Excursion 6.0 PSD + 2009 Salem 27' TT
08-24-2014, 03:53 PM
08-24-2014, 04:02 PM
you have a schwintech slide out and it has a crank?? never heard of that, take pict and i would like to see how it is attached to the motors (yes 2 ea) mounted in the upper corners
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
08-25-2014, 07:00 PM
In photo #2 notice the black material on the bottom of the slide. This is the same material that is on the bottom of my slide on my FR Grand Surveyor. Why do I bring this up? My unit has a "Lippert (or Lippet) under-sofa" mechanism that uses two six-inch long rollers for the slide to roll on when traveling in and out. That black stuff just does not work as a support for these (or any other) rollers. The rollers on mine had locked up and torn through that black stuff then dug into the plywood bottom of the slide. I had posted on this forum as to how I had to fix all of this.
08-25-2014, 08:04 PM
Thurman, thanks. I retract my slide three times a year before winter and twice when I go away with my kid I read your post before and will keep an eye on stuff. Thanks again
09-04-2014, 10:52 AM
Okay Gents, I'm new to all of this my slide is exactly as the one pictured in photo# 2 but I see no way to manually retract the slide, will some one please show the exact location of the manual override.
09-04-2014, 11:06 AM
came back from the.trip and everything worked as planned; )
09-16-2014, 09:33 AM
A "for what it's worth" comment: My slide has a Lippert "under sofa" unit that operates electrically (12vDC). But if something happens and one would need to manually operate the slide- -the drive unit is indeed under the sofa. You have to lay on the floor of the unit to reach it. There is a pin that has to be pulled which I believe dis-engages the drive unit, then there is a hex shaped protrusion that can be turned with a wrench or ratchet/socket. After I bought this unit I thought about manually moving the slide just in case I would ever need to do so. It takes a lot of turning this manual mechanism to get the slide to move and it's not easy. I did have somewhat of the opposite problem once. While returning home from a trip I noticed in my outside rear view mirror that my slide was out while going down the road at 60 MPH. I slowed down then stopped at the next place that was safe to do so and wound up literally pushing the slide back into place. I have no means of blocking the slide in the closed position so I just had to be careful getting home. It turns out that a shear pin had sheared within the drive unit itself. Not a bad job to replace it but I sure felt lucky to have made it on home.
