Old 12-12-2015, 01:01 PM   #11
slide outs
I have the same problem with my slides. Does anyone know the location of the fuse on a 2012 Georgetown 360? Any help would be greatly appreciated.
tzajack is offline   Reply With Quote
Old 12-12-2015, 01:55 PM   #12
I don't know how about the GT, since it is a MH. But on my TT, there were 2 separate inline 30A automotive style fuses, located just off the battery cutoff switch and along the driver side frame. My owners manual does not say anything about fuses. I hope you have a better manual. I am still learning where and how with a lot of things on my own and not in their great manual. If you cannot find them, call the factory or dealership. I don't know why you would have a similar problem but maybe you do have a bad battery? You should have 2 batteries, being you have a MH. If one is bad, it will drag the other one down.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is online now   Reply With Quote
Old 12-12-2015, 03:04 PM   #13
txredfish
You will need to watch your volt meter while the slid is being operated to see how far it draws your battery down.
Papa GLS is offline   Reply With Quote
Old 12-13-2015, 10:53 AM   #14
slide outs
Thanks for the reply. My manual is useless also. Both batteries seem good and slides still don't work when plugged into shore power.I've checked every fuse I can find.
fuse, slide, slide out
