I have a 2008 Palomino Sabre. Just tried to open the dining room & living room slides on battery power. Think I blew a fuse, but not sure. I checked all the fuses on the breaker box, but they seemed OK. Any suggestions where I might find the fuse or fuses that control those slides?
Look for the fuse or fuses within 18 inches (or so) of the battery. In a 5th wheel, they are located off the main battery protection current limiter (red covered current limiter). In a travel trailer they are located on the frame under or very close to the battery and can get corroded and fail.
The slide out fuse is usually 30 amps in a green or black fuse holder attached to a terminal of the main current limiter.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
