Old 05-29-2016, 07:53 PM   #1
SWA
Cherokee 274bhs electric slide not moving
Wondering if someone can help me out. I have a 2015 Cherokee 274bhs TT. The slide will not open. The slide motor works and the gear box is all good. The problem seems to be the actuator itself. It's and electric slide. When I try and and spin it manually still no luck. I keep hearing that shear pins break easily but I can't seem to find a photo of the internals of the actuator or where this "shear pin' is located.
When I take the motor and gear box off and expose this( this is not my photo just the closet I could find on the Internet) I can spin it freely and no slide movement. I imagine this is attached to some type of threaded coupling that pushes the threaded rod oh or in which in turn moves the slide. Can anyone point me in the direction of a blow up diagram? Or Know the part that has failed. It is at the dealership being looked at because it is still under warranty but I'd like to know for myself for the future.
Name:	ImageUploadedByForest River Forums1464569495.315736.jpg
This is the only diagram I can find in regards to the actuator
Name:	ImageUploadedByForest River Forums1464569580.915132.jpg
Thanks for the help
SWA is offline   Reply With Quote
cherokee, electric, slide
