Old 10-18-2014, 05:37 PM   #1
PhoneDude 8289's Avatar
Compression seals on slides
I was wiping down the seals 303 on the slide outs when I found the compression seal across the top of the wardrobe slide drooping on the roof of the slide, 3/4 of that seal wasn't touching anything when closed. I opened the slide and relieved the tension on the slide awning and disconnected the awning. I used a putty knife to remove the seal, cleaned and lightly sanded the frame the seal was attached to and used a strip of indoor / outdoor dbl stick tape from HD and restuck the seal to it. Time will tell how well it holds up, I will be keeping an eye on it but an 8' ladder is necessary to do that. Installed the slide awning and all is well.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 10-18-2014, 05:47 PM   #2
Witch Doctor's Avatar
Do you have picture. Maybe something I can check?.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-18-2014, 08:18 PM   #3
Below is a picture of the seal that wasn't attached correctly, not a good picture but there it is. An 8' ladder is needed to check the top seal on the wardrobe. In the picture the slide is open, the awning is disconnected and to the right. The white is the roof of the wardrobe and to the left of that is the dark brown frame of the wardrobe with the seal and part of that seal hanging down. The factory had double back tape on the seal so that's what I went back with. The seals on the other two slides were OK.
Joe & Beverly
2014 8289WS lifted
Old 10-18-2014, 08:25 PM   #4
Jerry01's Avatar
I had the same thing happen to one of my slide out seals. But my seal was the H seal (if that's what it's called), the one that is attached to the fixed part of the wall. When I opened the slide, the seal would pull away from the wall. I just used double sided tape as well. So far so good. I would say that you are good to go as well. Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
slide, slide out
