Old 06-26-2016, 05:47 PM   #1
Controller location on Rockwood 2703
Can anyone tell me where the slide out controller is location for the kitchen slide? The motor in the rear of the camper isn't working.
2014 Rockwood 2703 WS
2014 Chevy Silverado 1/2 ton
benitslu is offline   Reply With Quote
Old 06-27-2016, 10:29 PM   #2
The Flagstaff 27 rls is also the same floorplan.
I am able to easily find the wardrobe slide controller next to the water heater, but cannot find the other one.
I am hoping it is not the motor, since I won't be able to access the set screw from the exterior so I can change the motor?
Old 06-29-2016, 02:54 PM   #3
Old 06-29-2016, 09:02 PM   #4
gooiebob's Avatar
On our 2013 the controller is in the lower cabinet on the right side of the TV. I moved ours up to the next shelf so I could see it better.
Good Luck
Bob
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 06-29-2016, 09:04 PM   #5
Thanks. I looked there by actually filming it with my phone and didn't see it but I will try again.
What really stinks is that my slide is stuck in the in position making it really hard to get in the space.
Old 06-29-2016, 09:13 PM   #6
gooiebob's Avatar
Thats a tight fit if its stuck in. I don't remember if there was a false wall panel in there or not. It could be behind it. They are usually screwed to the floor. I removed all ours.
Old 06-29-2016, 09:16 PM   #7
Now I know. It will be moved when I fix mine. Wouldn't it make sense to put both of them in the same location by the water pump? Easy access and you can swap wires to see if the controller is bad.
cat, controller, location, rockwood
