Old 08-11-2019, 09:18 PM   #1
Correct hydraulic fluid???
Can anyone tell me the correct fluid to use in a Power Gear slide/leveling system on an 06 Charleston? I replaced all the hydraulic hoses and need to refill the system, looks like it may have had Dexron fluid.
wtbuck12 is offline   Reply With Quote
Old 08-11-2019, 09:39 PM   #2
LittleBill's Avatar
Most hydraulic systems use automatic transmission fluid. There are a couple of different types. The documentation for your system should have the information, I have a Lippert and it had it. I believe Dexron is common but check your documents. Per chance you don't have the documents then you might try to search on-line for it or call the customer service dept for your hydraulic system (Google phone no.). Just don't overfill if slides/leveling system are out/down. I made that mistake and had fluid on the ground.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 08-11-2019, 10:32 PM   #3
Thanks for the response. Unfortunately I don't have any paperwork on the unit, but will try to Google it, just thought I would try here first.
Old 08-11-2019, 10:37 PM   #4
Riverdude's Avatar
ATF
Riverdude is offline   Reply With Quote
hydraulic
