Old 02-21-2012, 03:31 PM   #1
creeping slide
I have a 2009 wildcat with 2 slides. Soon after the slides are extended, the bedroom slide begins to " creep " in. It will creep in about 6 inches in about 8 hours. The living room slide does not move at all. The 2 slides are controlled with one switch. Any suggestions???
Ted
fireman1865 is offline   Reply With Quote
Old 02-21-2012, 05:00 PM   #2
Dave_Monica's Avatar
Your slides are hydraulically operated? The hydraulic fluid could be leaking by the piston to the low pressure side, assuming that you don't have leaks anywhere. It sounds like a trip to the dealer to fix.
Dave
Old 02-22-2012, 07:55 AM   #3
Lottery Non-Winner
Ovair's Avatar
If they're hydraulic, I side with Dave.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
