Old 06-10-2019, 10:55 AM   #1
Creeping slide outs on Cardinal 29TS
Slides were slow operating and I would notice as I traveled the kitchen slide would creep out. Would stop and bring it back in only to happen again. Problem was caused by a bad piston seal in cylinder for LR slide. Retraction pressure was very slowly leaking through the seal to the extension side and forcing other slides to extend 1-2”. Problem solved when I had cylinder rebuilt. Forgot to mention that cylinder totally failed in extended position Hope this is beneficial to someone
McFord94 is offline   Reply With Quote
Old 06-11-2019, 09:20 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Some of the older class A rigs like Winnies had travel latches on the slides to stop that (slides were hydraulic) thanks of the info
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
cardinal, slide, slide out
