Crusader 325res Slide Out
Has anyone had to manually retract or extend their slide outs on a Crusader325res? I was lubing the slide out gears today and got to thinking about what if's. I can't see anywhere to get to the drive motor, it is inside the frame. I read Lipperts PDF but there is no access from the outside of the frame. Would I need to cut open the bottom plastic protector thing to access it?
TIA
Rick
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
