Old 06-07-2012, 08:20 PM   #1
delay when putting out slides?
We just got back from a 12 day trip to the Smokey Mountains and noticed when we were sliding out and retracting the slides that there was a pause about every 3 seconds when the slides are moving. When we first got our camper home the slides extended and retracted without this pause. Its a 365 saq sandpiper. Any ideas what could be causing this pause?
carsonizik3 is offline   Reply With Quote
Old 06-07-2012, 08:29 PM   #2
TURBS's Avatar
Sounds like a self resetting circuit breaker bad or to small of amp . imo
Need to put an amp meter on power cable to slide.
Old 06-07-2012, 09:23 PM   #3
Herk7769's Avatar
Since you did not mention the year of your camper, when was the last time you lubricated the slide mechanism?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-07-2012, 09:31 PM   #4
TURBS's Avatar
Good point.
Old 06-07-2012, 10:20 PM   #5
Dave_Monica's Avatar
Just to clarify. How long is the pause? Is the slide drive electric or hydraulic?
Dave
Old 06-09-2012, 05:07 AM   #6
cpaulsen's Avatar
A lot of times there are 2 40 amp breakers that control the slides....swap them out for 50 amp ones.
cpaulsen is offline   Reply With Quote
Old 06-09-2012, 06:10 AM   #7
Herk7769's Avatar
IMO, this is a bad idea. If the motors are drawing higher than rated current, a fire is not far behind. An auto-resetting 40 amp breaker might be a better option as it will allow the motor and wires to cool before re-applying power.
led pad
