Old 06-26-2016, 08:09 PM   #1
Dining slideout "slides" out
I have a 2013 390BH and on the last trip the slide out was creeping out while i was driving home. I put the slideouts in this morning and when i came home it had crept out about 4 inches. any suggestion??
Stoneking is offline   Reply With Quote
Old 08-10-2016, 06:59 PM   #2
Hchoice16
I am having the same problem.
Did you ever get a response to your post?
Gary Hobson is offline   Reply With Quote
Old 08-10-2016, 07:09 PM   #3
dan-nickie's Avatar
Guys, you will get lots of feedback if you post in the "Berkshire" section.
First thing to check is the hydraulic fluid level at the pump.
It should be checked with all slides in and jacks up.
And welcome to both of you.
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 09-06-2016, 11:13 PM   #4
large slide out will not side on one end
Any one that knows I have 2004 cardnal with 3 slides 38 ft 5th wheel
bed room and couch slide work fine the dinning and tv slide works on one end have to hand push other to keep them going in together they all seal up fine any suggestions ?
AndyCoats is offline   Reply With Quote
slide, slide out
