Old 07-04-2018, 06:10 PM   #1
Do all slides click when they stop?
On our old TT, Springdale with Lippert slides, they would click when stopping in or out. Our new TT did that a few times but lately there is no click when they stop. Called dealer and he said these slides are different than the previous TT, these are cable drive, and they don't always click. He said the Lipperts don't always click either. Also these slides sound as though they are working harder to move the slides than our previous TT. Not having anything to compare except our previous TT I asked the dealer about that as well. He said again different system. Not that I don't believe him, ok maybe I don't, but thought I would ask here for input. Thanks in advance for your replies.
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is offline   Reply With Quote
Old 07-04-2018, 06:22 PM   #2
Just as confused as you
Scrapper's Avatar
The Lippert slides with the rack and pinion drive mechanism clicks at the end of travel. It has a clutch mechanism to prevent damage. The other types I'm not familiar with.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 07-04-2018, 06:25 PM   #3
X2
2014 Ram 1500 HEMI Lone Star Edition
2018 Coachmen Freedom Express 248RBS
2017 Harley Davidson Road Glide
Roberte52 is offline   Reply With Quote
Old 07-04-2018, 09:55 PM   #4
bikendan's Avatar
Schwintek slideouts don't click.
Equalizer WDH
Old 07-04-2018, 10:27 PM   #5
SailorSam20500's Avatar
The Lippert on our large slide clicks. The Schwintek on our wardrobe slide never does - just gets quiet.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 07-05-2018, 12:59 PM   #6
Thanks for the info Scrapper, but the question that has always resided in my mind is: IF you run the slide in/out to the point of the clicks, does that create premature wear and tear on the clutch mechanism?
I'm always very conscious of stopping just before the click; the WD runs right through it and clicks it about 5-6 times.
I'd hate to have that clutch system break down....
J.
jcrayford is offline   Reply With Quote
Old 07-05-2018, 01:10 PM   #7
J.
I suspect it would take 20 years of daily use to wear it out...
Al
S.E. Mich.
Old 07-05-2018, 01:12 PM   #8
J.
We were advised by the dealer specifically to let the mechanism click in/out to make sure the slide has reached full movement. If stopping before the clicks, it is not fully in/out and not properly sealing.
We also have slides that no not click. We were told to keep the switch depressed for a couple seconds after movement stopped.
PenJoe is offline   Reply With Quote
Old 07-05-2018, 01:16 PM   #9
Denver To Yuma In 90 Days
Now that my 5'ver is three years old I noticed that two of my three slides don't click as much as they used to.
However, it does it more when I'm plugged in to shore power than it does when I'm running them in or out on battery power.
The third slide is hydraulic, so it makes a strange whiney sound when it reaches the end in either direction.
JohnD10 is offline   Reply With Quote
Old 07-05-2018, 02:41 PM   #10
Retired and Loving Life!
Alan F's Avatar
Send a message via MSN to Alan F
My bedroom slide does not click but my kitchen slide does. I was told by service tech to keep the button pushed for three seconds on each after full extension/retraction to keep the motors synchronized.
Alan F is offline   Reply With Quote
Old 07-05-2018, 02:50 PM   #11
My old trailer had a Lippert slide. After 3 years of clicking it stopped sliding - diagnosis: stripped gears. The tech explained that the gears are made of brass. $880 later and doing the repair myself on the road, I stopped with the clicking.
kirkwilliams2049 is offline   Reply With Quote
Old 07-05-2018, 03:16 PM   #12
Georgia Rally Coordinator
aceinspp's Avatar
The clicking is normal. What hurts the slide is if you stop and start them when putting in or putting out. You should never stop half way any time always fully extend or retract without stops. This results in premature failure. From a seminar given at the Georgia Rally this year. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 57
aceinspp is online now   Reply With Quote
Old 07-05-2018, 07:03 PM   #13
Bene Gesserit Rule
Murbella7's Avatar
Originally Posted by Roberte52 View Post
X2
X3. The clicks tell me when to take my finger off the button.
Murbella7 is offline   Reply With Quote
Old 07-05-2018, 07:10 PM   #14
And the Dexter axle factory engineer at an RV rally looked at my 5'ver and told me that my axles were bent...
Of course...he blamed me for overloading since they were still under warranty!
And the axle shop I took it to for repair said there was nothing wrong with them.
Turned out I had a tire separating, which is what was causing the tire wear!
I frequently put my slides out partially, especially during lunch stops on the road (kitchen is in the slide up against an island when closed), and they don't seem to show any signs of wear and tear!
Old 07-05-2018, 07:14 PM   #15
My knees click when they go up and down. Do you think I got bad knees?
yakmeat123 is offline   Reply With Quote
Old 07-05-2018, 08:50 PM   #16
Bene Gesserit Rule
Murbella7's Avatar
YES
Old 07-05-2018, 08:55 PM   #17
Time for "Copper Fit".
Al
S.E. Mich.
slide
