Old 04-07-2010, 05:16 PM   #1
flirtypup's Avatar
Question Do you use slide out supports?
Never had a unit with a slide before. Dealer says dont use supports, others say use supports. Someone please help. Do you use slideout supports?
id rather be in my hammock
flirtypup is offline   Reply With Quote
Old 04-07-2010, 05:58 PM   #2
ARLO
Supports
I had some made for our first slide out in 1995.Used them for one year then sold them in a garage sale. We have had slides ever since and have never needed them.
rlocicero is offline   Reply With Quote
Old 04-07-2010, 06:10 PM   #3
Knower of Some Things
If you use them, be careful about how. Make sure the supports "just barely" contact the bottoms of the slide arms. If they are actually supporting it, the seals around the unit will break/touch/break/touch/break and so on, causing problems both immediately with wear & leakage and water damage farther on down the road. Make sure you don't forget about them before you pull in the slideout. They're good for support if someone flops down on the couch, mainly. The unit won't suddenly rock as much, even with regular stabilizer jacks down. The structures on most trailers are made to support the slideouts.
PumaPro is offline   Reply With Quote
Old 04-07-2010, 07:59 PM   #4
Now a "Top Member"
EdJunior's Avatar
No, you do not need them. The slides were made with weight on them in mind. If there was a need for support, it would be provided (as in the rear slides of some TT's, or the Pop ups). If it did not come with a support, it does not need it.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 04-08-2010, 07:27 AM   #5
cardinal4fun's Avatar
Waste of time, money and everything else you can think of. My first fiver I purchased two to support the large slide. Trying to get them just right, not to tight not to loose was a never ending battle. To tight maybe bend something or who knows what even worse. To loose it will fall down. I still have them they make great work supports
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 04-09-2010, 10:47 AM   #6
bikendan's Avatar
NO, from what i've read, these were good for the earlier types of slideouts. but the newer ones don't need them.
Old 04-09-2010, 09:40 PM   #7
milzat's Avatar
Slide supports be a No No.
They're not worth the $$. They can cause leaks at the sealing area.
milzat is offline   Reply With Quote
