Old 10-16-2016, 05:19 PM   #11
Left Coast
The bead channel doesn't come with the topper?
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 10-16-2016, 06:10 PM   #12
Tim Coltrain's Avatar
In the last picture I put a Red straw which is what I believe to be the channel you are referring to.
Tim
Tim & Rita Coltrain
2012 Chevrolet 2500 Duramax Crew Cab, Allison Tranny.
XLR Thunderbolt 2016
Tim Coltrain is offline   Reply With Quote
Old 10-16-2016, 06:13 PM   #13
Tim
Yes! Youroo!!
Old 10-16-2016, 06:23 PM   #14
Toppler Installation -Thank You to All the Responded
I have learned alot in the last few hrs and I'm grateful for everyone's imput.
As I see it when I get the Dometic Topplers in the hardes part of the task is mounting the brackets to the Slider. Once brackets are in place its a matter of sliding the vinal into the slot. I do assume I remove one of the rain trays and put it back up once vinal has been installed. Hopeuflly thats all that will be needed.
FYI-The reason I ask alot of questions is because I work in Construction and I have learned over the years you have to do what is a PTP-Pre Task Plan and understand the task before you take on the task.
Again Thanks for the help.
Tim & Rita Coltrain
Old 10-17-2016, 10:06 AM   #15
Head Rambler
The red straw did it! Now you know that you have the bead track, and the awning will just slide into it.
Now the hardest part is going to be mounting the brackets to the slide wall. And that's not too big a job.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-17-2016, 10:11 AM   #16
Head Rambler
I've read some descriptions that specifically say the rail comes with the awning, and some aren't clear about it.
The best thing for anyone who needs the rail, to do before ordering the awning, is to ask the vendor to make sure you get it.
Gotta go campin!
Old 10-17-2016, 10:18 AM   #17
Left Coast
I'd do that just because....
dometic
