Closed Thread
Old 07-09-2013, 07:18 PM   #21
Originally Posted by bakken View Post
Push at the top of the slide, not the bottom.
Really? Amazing what one can learn here. Boy, I sure wouldn't have known that without your help.
OldCoot is offline
Old 07-09-2013, 07:23 PM   #22
Originally Posted by herk7769 View Post
X2 - I always use mine as I have the same mechanism that Bakken has.
Agree, mine is the same and if it starts to move the face board is held in place with staples. So far I guess we've just been lucky. When the slide comes in on ours, the top hits at least 2" before the bottom hits.
OldCoot is offline
Old 07-09-2013, 07:49 PM   #23
Herk7769's Avatar
Maybe one of us has a slide out of adjustment. When mine comes in, the very first thing is the bottom lifts up. This tilts the slide so the top is tilted outwards.
As the slide comes in, the slide "topples" into the camper slightly as the center of gravity of the slide passes the 1/2 way point. This releases the weight on the spring loaded pinion gear tracking assemblies.
In this configuration, the top of the slide may contact the wall first but there is very little pressure to compress the top seals. Continued running of the motor pulls the bottom in until the bottom of the slide hits the outer wall.
The top seal in mine now rests on the outer wall but is not tight (though the bottom is).
When I install the slide brace (as in the photo), as I tighten the brace, the top pulls in compressing the top seal (light that was visible in the corners is extinguished) and the slide rotates slightly into the camper re-compressing the pinion gear spring pack.
Note: There is a clutch in the motor driven gear pack that can release (and in fact does so every time you reach full extension and retraction - that clacking noise). If the slide does not have the transit bars in place, a sharp enough shock can unlatch that clutch and allow the slide to move. Once in motion the weight of the slide may very well allow the slide to continue to full extension.
File Type: pdf 0002-gear-pack-replacement-embedded-rack.pdf (144.8 KB, 15 views)
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 07-09-2013, 07:54 PM   #24
Rugged Brown's Avatar
I didn't get any rods with my new camper. I have looked back at the slides in the truck mirror when travelling ( we have rough roads in NS) and I have never seen any movement of the big slide. As OC states, if there was movement, I would doubt if the trim will stay intact with the way it is slightly attached. I'll have to give this one to OC. Sorry Bakken.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline
Old 07-09-2013, 07:58 PM   #25
I had never heard nor seen these sticks before reading this post. There must be different slide configurations that require these during transit? The slides on our trailer lift up before moving out and then drop into position at the maximum extension.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline
Old 07-09-2013, 08:09 PM   #26
Herk7769's Avatar
Yes. There are different mechanisms that control the slides. If transit bars did not come with your (new) unit, you most likely have a system that does not need them. The NORCO wardrobe slide in our bedroom does not use them, for example, as it is chain and cable driven. The slide will not move (ever) without turning that motor using a tool I almost threw away.
I applaud Rugged's ability to see his camper's slides while traveling.
I can barely see my camper in our truck's dinky mirrors.
Name:	Wardrobe Slideout Motor.jpg
ID:	34950   Click image for larger version
Name:	Flex Drive Tool.jpg
Herk7769 is offline
Old 07-09-2013, 08:09 PM   #27
Great info in the attachments Herk.
Maintenance indicates no lube! I think many dealers would be surprised at this.
Here is the wording from your attached PDF
SYSTEM MAINTENANCE
The Lippert Electric Slideout System has been static tested to over 4,000 continuous cycles with out any noticeable wear to rotating or sliding parts. It is recommended that when operating in harsh environments (road salt, ice build up, etc.) the moving parts be kept clean and can be washed with mild soap and water. No grease or lubrication is necessary and in some situations may be detrimental to the environment and long term dependability of the system
Doering is offline
Old 07-09-2013, 08:12 PM   #28
Have to agree with Lou and RB both, I have never seen any movement or evidence of movement on the top of the slide on either of the main slides of our 2 Flagstaffs. I just don't believe the trim is secure enough to hold the slide if the track should release. I may be wrong, and if so, I guess I'll suffer the consequences and have to eat some crow. Wouldn't be the first time I've tasted that bird.
OldCoot is offline
Old 07-09-2013, 08:13 PM   #29
Herk7769's Avatar
Many mechanics would be surprised it is not still 1931...
Proof? Look at the wall calendars...
Herk7769 is offline
Old 07-09-2013, 08:19 PM   #30
Herk7769's Avatar
One of the big misconceptions is that the brace somehow restrains the slide.
It does not.
The brace puts pressure on the spring loaded pinion to keep it in contact with the rack at all times. Without the brace, the teeth of the pinion can skip out of the rack under a sharp load (or even break off). The clutch in the motorized gearbox is not sufficient to hold the slide if it starts moving.
Read the Lippert flyer on replacing the spring loaded pinion gear.
Herk7769 is offline
Closed Thread
