Old 01-04-2020, 01:33 PM   #1
frank4711's Avatar
First trip warranty slide/drawer
Had appointment today for slide and a drawer that needs new hardware .... Slide has no power they checked what I had already checked and agreed needed to see motor and wiring under belly cover ... service boss asked permission to make a slice in belly cover he said he had tape that would seal it ( https://www.rvupgradestore.com/Surfa...RoCvWMQAvD_BwE exactly what he used ) I said sure .... he took a look and said looks like a wire was run over the track for the other slide and it is getting pinched ... he attached battery supply to power motor and it came on so not the motor .... took pictures best he could and said they would submit to Forrest River the need to rewire ... underbelly cover will need to come off so I asked that a new one be installed and he said he would see that it was done .... and they will order new hardware for drawer .... the head of service and his tech were helpful .... It was also good because the service guy/boss Gary I knew we did lawn maint in Sarasota for 25+ years ... so will see when they get approval how it goes
Frank & Cindy ... Rockwood 2888WS Ultra Lite 5th Wheel---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed---Remi & Sage camp pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Goodyear Endurance ... Predator 3500---48 days 2019---Payload 4394
frank4711 is offline   Reply With Quote
Old 01-05-2020, 08:20 PM   #2
frank4711's Avatar
Checked slide after got home it is working again ... while inspecting they must have moved some wires around ... still will have work done to re-wire clearly there is a loose one
first trip, slide, warranty
