Old 07-04-2015, 10:28 AM   #1
wnelsonfl's Avatar
flagstaff slide blowing fuses and shearing bolt.
My slide frequently blows the 30 amp green fuse near the battery. I have also sheared the bolt that is necessary for the slide to work. I thought this was a unique problem until I spoke with someone with the same TT that sheared his bolt twice. He brought it to the factory and they made adjustments to the stops he thinks.
Anyone else had this problem on a 21 fbrs or rockwood twin.
PS Camping world spliced out my 30 amp fuse. Said it shouldn't have been there. That doesn't seem right.
Warren
2014 Silverado Z71 4x4- 5.3
Flagstaff 21 FRBS
235 nights camping this past 30 months
31000 miles
wnelsonfl is offline   Reply With Quote
Old 07-04-2015, 10:41 AM   #2
I used to have a 21FBRS and I 'm thinking that the inline fuse was 30 amp? CW's removing the fuse altogether seems pretty risky to me.
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
Old 07-04-2015, 10:53 AM   #3
wnelsonfl's Avatar
You are correct it is a 30 amp. You must be familar with this problem?
Warren
Flagstaff 21 FRBS
31000 miles
Old 07-04-2015, 11:18 AM   #4
I had one episode with a stripped shear pin in the slide mechanism, which the dealer was able to fix by fabricating a new pin. I then discovered the inline fuse, which had not been pointed out to me during the PDI. It never blew but I made sure I had a replacement handy.
We loved our 21FBRS and covered a lot of miles in it.
Old 07-04-2015, 11:55 AM   #5
GlacierGus's Avatar
Warren, I have a 2013 (constructed in 2012) Mini Lite 2109S which is the twin to your 21 FBRS. I'm in my 4th season. The 30 amp fuse has blown twice so I just keep spares handy. I don't know why CW would remove the fuse. It's easy to replace the fuse. The slide bolt broke for the first time this May. Neither have been major problems. Just something to deal with from time to time.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 07-04-2015, 12:17 PM   #6
Loneeagle's Avatar
I have a 2015 21 FBRS. Have only used a few times, so far no problems. With this bold sheer you are talking about where is it and what do you do if it does happen while camping? I'm not a mechanical genius.
Ford F-150 4X4
2015 Flagstaff Micro Lite FRBS
2013 Flagstaff "A" Frame - Traded Up.
Camping Days 2013 - 24
Camping Days 2014 - 21
Projected Camping Days 2015 - 30
Loneeagle is offline   Reply With Quote
Old 07-04-2015, 12:23 PM   #7
Check lubrication. That will help. Make sure the motor is stopping at end of travel and not binding which will cause overload and shear pin issues. Fuse could be replaced with an auto resetting circuit breaker
Harkerr is offline   Reply With Quote
Old 07-04-2015, 12:25 PM   #8
I have a Flagstaff 23FBDS which is now two months old
It blew the 30 AMP fuse (same location as yours) the day before I picked it up from the dealer and three times after that.
Dealer replaced fuse with 30 AMP breaker that auto resets
By the way this was the dining slide
They still don't have a cause, but at least it works OK now
vinceigo is offline   Reply With Quote
Old 07-04-2015, 12:40 PM   #9
Crockett's Avatar
if your shearing pins, youve got an adjustment issue. do you level the coach by pulling onto blocks? i would not level using leveling jacks...just stabilize. the fuse could blow due to a low battery. you could just put a breaker in there.
Crockett is offline   Reply With Quote
Old 07-04-2015, 12:44 PM   #10
Slide pin sheared
We had this same problem with the closet slide in our 2013 Rockwood ultralight fiver. My husband fixed it but the pin WAS sheared off. He fabricated a new pin
Dkjones28 is offline   Reply With Quote
flagstaff, fuse, slide
