Old 10-08-2018, 12:26 PM   #1
Flooded out door kitchen
Wondering on 365saqb what the wood material that the underside is made of. It is black. Wondering if itís material that is more water resistant. Hoping it is more forgiving when getting wet ONCE. Someone left the sink running and filled up GALLEY tank and overflowed the sink. . Another mess for me to clean up and fix. . Running dehumidifier and fans after cutting and removing carpet, Removing drawers, drawer supports, and bed trim from inside.
quick83 is offline   Reply With Quote
Old 03-12-2019, 04:04 PM   #2
Here are the before pictures. When Iím done I will post after pics. Laminate is installed. Will cut out faucet holes and sink when glue dry and reinstall sink and new faucet. Click image for larger version
ID:	198604Click image for larger version
ID:	198605Click image for larger version
Old 03-14-2019, 07:17 AM   #3
Camper
Keep the photos coming. Was the counter water damage too much to save?
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 03-14-2019, 07:48 AM   #4
Not sure what you mean but the water left on was hot and steamed the laminate off in a lot of places. Had to remove old laminate. It was not to bad but took some work. Had to trim it 5 times for really good fit. The water did not cause any damage because most ran out the way the Rv was leaning. Only minimal water went inside and all I had to do was remove carpet some carpet and dry it out. (I have a good dehumidifier).
Old 03-14-2019, 07:50 AM   #5
Camper
I misunderstood your OP. I thought the "wood" under the laminate was damaged. I get it now. In any event keep the photos coming as the repair progresses.
Thanks,
Brian
Old 03-14-2019, 07:51 AM   #6
Old 03-14-2019, 07:52 AM   #7
Old 03-14-2019, 08:03 AM   #8
Had to wait 3 days for glue to cure. Then will cut holes to reinstall the sink and faucet.
Old 03-14-2019, 08:29 AM   #9
Thank the lord the wood was not damaged. NOT even swollen any where!!!
Old 03-14-2019, 08:42 AM   #10
Camper
I like the laminate. Was that the same original laminate design.
Thanks,
Brian
door
