Old 06-28-2013, 10:24 PM   #11
Owner/Operator
RodeoGeorge's Avatar
Originally Posted by BobSledge View Post
I also noticed that there is a space between the slide trim and the wall when in the extended position. It is sealed. Guess I am just used to my old slide that seemed more flush and tighter to the wall.
This might suggest that the slide is not going all the way out, and therefore dropping down to become level.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 08-08-2013, 12:27 PM   #12
GSW
It is not normal. I have had other units and they have had no hump. Does anyone know how to fix this problem?
GSW is offline   Reply With Quote
Old 08-08-2013, 12:33 PM   #13
B and B's Avatar
My 5er has the same carpet bump OC mentioned as well. It is pretty flush i would say.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-08-2013, 12:49 PM   #14
Brother Les's Avatar
I believe for his unit that it is 'normal' .....
I have seen some dialog about 'supported' slide out floors and 'unsupported' slide out floors when the slide out is 'in'.....
In looking at ependydads picture, it would seem that his is 'unsupported' when it is 'in' (imo). My slide out has the 'hump' when 'out' and the 'hump' when 'in' and it seems to be fully 'supported' when 'in'. No movement at all when I walk on either slide out when 'in'.
Brother Les
Old 08-08-2013, 01:05 PM   #15
Fulltime family RVer
There's no opinion about it. You're 100% correct. My slide is not supported when it's in. I've got a post or two here with a factory rep saying that it should not be walked on when the slide is retracted.
ependydad is online now   Reply With Quote
Old 08-09-2013, 11:52 AM   #16
VinceU's Avatar
Surprised that rep told you not to walk on it when retracted. Its the same support steel and wood base in both positions. The only difference is the square tubing on the slide is no longer in full contact with the c-channel support, it will rock on its edge, so what? still plenty strong. The frame kicks up to allow it to rise above the main floor for storage.
Old 08-09-2013, 01:00 PM   #17
It's the plywood of the slide floor that isn't supported when it's in. This is only my understanding- but when the slide is fully extended in the "out" position, the inner edge of the plywood is supported beside of the floor that it slides down next to (not sure what's supporting it, but it definitely comes down to rest on something). It's firm. Solid.
Now, when the slide is fully retracted, that same inner edge is pushed inside the camper and it lifts as it comes in. When you get on the floor level, that plywood is a good inch above/off/not touching the floor below it. If you do step on it, there is give. Imagine you had a piece of 4x8 plywood on saw horses and you push down on the middle- it'll bow.
That's my slide floor.
