Old 06-25-2013, 07:45 PM   #1
Flush Floor Slide
When the a flush floor slide is extended, is it normal for their to be a slight rise where the slide floor stops? It is covered by carpet, but where the slide floor begins, there is a a 1/2" rise.
2014 Heritage Glen 272BH
BobSledge is offline   Reply With Quote
Old 06-25-2013, 08:35 PM   #2
Normal.
Old 06-26-2013, 03:56 PM   #3
I have the same rise on my 2012 V-Cross 275 fiver. I just thought it was normal?
whj77372 is offline   Reply With Quote
Old 06-26-2013, 04:35 PM   #4
Dennis and Julie's Avatar
Totally normal.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 06-27-2013, 07:33 AM   #5
Fulltime family RVer
Hmm. Ours is pretty well perfectly flush when the slide is fully out. When it's in, there's a step up and the floor isn't supported- but that's what I would expect.
Y'all say this is normal? Wouldn't that make it an "almost flush floor" then?
ependydad is online now   Reply With Quote
Old 06-27-2013, 08:39 AM   #6
Thanks everyone. The rise is pretty well hidden by the carpet, but you can see it and when you step on it, you notice it.
I also noticed that there is a space between the slide trim and the wall when in the extended position. It is sealed. Guess I am just used to my old slide that seemed more flush and tighter to the wall.
Old 06-27-2013, 08:47 AM   #7
Of all the campers we've been in with slides, we've never seen a slide that is flush with the floor. There might be a slide mechanism that raises the slide before retracting, but I haven't seen one.
Old 06-27-2013, 09:41 AM   #8
I'm fairly certain that's what mine does. It kind of slides down into place and back up.
I'm going to run out and pull the carpet up to see how flush it really is. But, I'm fairly positive that I don't have any kind of lip in our living room where the love seat and dinette are. The slide is out entirely right now while we get ready for the next trip.
I'll take a picture and post it..
Old 06-28-2013, 09:08 PM   #9
Maybe the OP's slide is normal, but the main slide on my camper really does slide down and is flush with the main floor.
ID:	34185   Click image for larger version
Old 06-28-2013, 09:15 PM   #10
I think ours is the same, it's just the double carpet makes a hump. I'd go check to make sure, but we're having a real 'frog strangler' rain right now and for the last hour.
Old 06-28-2013, 10:24 PM   #11
Owner/Operator
RodeoGeorge's Avatar
This might suggest that the slide is not going all the way out, and therefore dropping down to become level.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 08-08-2013, 12:27 PM   #12
GSW
It is not normal. I have had other units and they have had no hump. Does anyone know how to fix this problem?
GSW is offline   Reply With Quote
Old 08-08-2013, 12:33 PM   #13
B and B's Avatar
My 5er has the same carpet bump OC mentioned as well. It is pretty flush i would say.
Brian
Old 08-08-2013, 12:49 PM   #14
Brother Les's Avatar
I believe for his unit that it is 'normal' .....
I have seen some dialog about 'supported' slide out floors and 'unsupported' slide out floors when the slide out is 'in'.....
In looking at ependydads picture, it would seem that his is 'unsupported' when it is 'in' (imo). My slide out has the 'hump' when 'out' and the 'hump' when 'in' and it seems to be fully 'supported' when 'in'. No movement at all when I walk on either slide out when 'in'.
Brother Les
Old 08-08-2013, 01:05 PM   #15
There's no opinion about it. You're 100% correct. My slide is not supported when it's in. I've got a post or two here with a factory rep saying that it should not be walked on when the slide is retracted.
Old 08-09-2013, 11:52 AM   #16
VinceU's Avatar
Surprised that rep told you not to walk on it when retracted. Its the same support steel and wood base in both positions. The only difference is the square tubing on the slide is no longer in full contact with the c-channel support, it will rock on its edge, so what? still plenty strong. The frame kicks up to allow it to rise above the main floor for storage.
Old 08-09-2013, 01:00 PM   #17
It's the plywood of the slide floor that isn't supported when it's in. This is only my understanding- but when the slide is fully extended in the "out" position, the inner edge of the plywood is supported beside of the floor that it slides down next to (not sure what's supporting it, but it definitely comes down to rest on something). It's firm. Solid.
Now, when the slide is fully retracted, that same inner edge is pushed inside the camper and it lifts as it comes in. When you get on the floor level, that plywood is a good inch above/off/not touching the floor below it. If you do step on it, there is give. Imagine you had a piece of 4x8 plywood on saw horses and you push down on the middle- it'll bow.
That's my slide floor.
