Old 05-26-2018, 10:04 AM   #1
Forest river 2018 slide out at angle-
We went to put the slide out for the first time this season and the front went out 12 in but the back did not move. Any suggestions?
sunseeker56 is offline   Reply With Quote
Old 05-26-2018, 10:12 AM   #2
fonzie's Avatar
You probably have a Schwintek slide system which has a motor on either side of the slide. Here are some you tube videos to help you
https://www.youtube.com/results?sear...chwintek+slide
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-26-2018, 10:23 AM   #3
Thanks!
Old 05-26-2018, 01:58 PM   #4
Originally Posted by sunseeker56 View Post
Thanks!
Should the engine on RV be running when you retract or extend the slide out if you are hooked up to shore power?
Old 05-27-2018, 02:16 PM   #5
Schwintek troubleshooting guide attached. Hope it helps. Also has factory phone number.
bob5560g is offline   Reply With Quote
Old 05-27-2018, 02:18 PM   #6
SeaDog's Avatar
No the engine should be off you should either be hooked to shore power or have hour generation running.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-27-2018, 07:41 PM   #7
Thanks! We are exhausted! We have had nothing but problems with this new unit. Finally had a mobile RV mechanic come out. He didn't have much knowledge on RV. Charged us and went on his merry way. Had another mechanic come out and he worked two hours. He had to take the side rails off and still could not get the unit in all the way. About two inches out. Now I'm scared to drive it to the dealer. So tired of all the problems we have had! It is a lemon!
forest river, slide, slide out
