Old 10-23-2013, 01:54 PM   #1
Forester 3171 Bedroom slide slow going out
I've noticed over the last year or so that when putting the slide out it seems to get slower and slower even when plugged in to shore power.
Coming in is fine, the rig is going on it's 4th year of use, is it possible the batteries are getting weak or do I need to adjust the motors? I've sprayed the rails with slide lubricant and it seemed to help the first time but that didn't last long.
I believe the bedroom slide is the Schwintek InWall Slide.
Any ideas?
thanks
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
torino421 is offline   Reply With Quote
Old 10-25-2013, 09:44 AM   #2
GM
bclemens's Avatar
I just posted this site on the forum. Not sure if it helps, but I see there is a troubleshooting flow chart.
Even plugged in, I think the slide is running off of batteries. That may be the issue, since it needs the proper voltage....but maybe the info here will help give you a better answer.
Schwintek Service and Warranty
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 10-25-2013, 11:05 AM   #3
dcheatwood's Avatar
In preparation for a dry camp hunting trip, I added distilled water and put a reg battery charger on my battery overnight. The next day, after removing the charger, my slides were noticeably faster than ever before. Maybe add distilled water and charge battery. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 10-29-2013, 07:08 PM   #4
thanks for the replies. Battery voltage is like it's always been when plugged in, around 13.6 volts but I know from experience that just because a battery has the proper voltage doesn't mean they are at peak power. The factory batteries are no namers so I'm guessing just cheap group 27's. Probably replace them this winter, not sure with what yet...wish I could fit 6 volt batteries.
Prior to any boondock trip, I always top the batteries off with distilled water and charge them with a regular car battery charger.
I sprayed the rails AND around where the motors gear meets with the rail with dry lubricant and this seemed to help. It's still slower going out then coming in though.
SOLD!
Old 10-29-2013, 08:34 PM   #5
VinceU's Avatar
Try cleaning cable connections both at the power supply source lugs (circuit breaker or resetable fuse) and at the input to the Swintek controllers. Remove cable clean fittings and reinstall with electric grease. Do the ground lugs also. Can loose a couple volts to corrosion and heat loss.
Old 10-29-2013, 08:49 PM   #6
dcheatwood's Avatar
Definitely sounds like low voltage. Battery has tested good on voltage. Bad connectors, shorted ground. I'm with you. These simple checks should solve the problem unless slide is dragging.
Old 10-30-2013, 04:06 PM   #7
If RV batteries are like auto ones, you don't get the best. Even though they are not the same type of batteries as auto, knowing what I know of RV makers, I would bet that we are getting something less then top of the line. After four years, I would repalce then. Good Luck
whj77372 is offline   Reply With Quote
Old 10-31-2013, 01:26 PM   #8
If you check voltage when plugged in you are reading converter voltage. Turn battery switch off and recheck at batteries
Priusron is offline   Reply With Quote
bed, bedroom slide, forester, roo, slide
