Old 02-02-2019, 05:10 PM   #1
Forester slide out 3015S wonít fully extend
My full length slide won’t fully go
Out. Am guessing house batteries may not have enough power because of last weeks bitter cold. Will it fully charge when driving?
I am plugged in to 30 Amp service. And nothing appears to be blocking the slide inside the coach or on the outside.
Lynnac is offline   Reply With Quote
Old 02-10-2019, 08:26 PM   #2
Did you ever figure it out?
Retired Chief USN
2017 Sunseeker GTS 2800
charles l is offline   Reply With Quote
Old 02-10-2019, 10:09 PM   #3
Usually Confused Member
emm-dee's Avatar
I believe you’re talking about a 3051. The slide is powered by the house batteries. If you disconnected the batteries they were not getting charged via the 30 amp connection.
I have that model and it’s always connected to shore power plus I never disconnect the batteries...too much stuff won’t work. I’m pretty sure driving will not charge them.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 02-11-2019, 04:07 PM   #4
Thanks!! Yes I am learning all the “tricks”.
As it turned out - a metal ring that is on the external of the awning had loosened ( and had 1 screw vs 3) so it had bent and obviously was rubbing. So the slide motor detected the awning would roll out it stopped.
The only reason we even looked there was I had experience with a manual awning that always had to be “unlocked” before you unrolled it. And so my RV repair shop guy climbed up there and found that.
When we took the bent one off, slide went out. So for now.... all is good!
Old 02-11-2019, 04:09 PM   #5
When we took the bent one off, slide went out. So for now.... all is good! Thanks!!!
forester, slide, slide out
