Old 03-28-2016, 11:49 PM   #1
Gap between slide and floor when closed
We recently removed our jack knife sofa and u shaped dinette and replaced with a reclining love seat and small table and 4 chairs. Now when the slide is closed it does not lay flat on the floor but has about a 1" gap between the slide and the floor. Cannot figure out what is causing that. Thought maybe because the dinette was heavier then the table but not sure how that wod affect it. We have a Vibe 272bh. Any suggestions would be great. I am hopefully we did not do any damaged when we removed the furniture. Not sure how it was very easy and only needed to remove a few screws.
miduncan is offline   Reply With Quote
Old 03-29-2016, 01:47 AM   #2
Witch Doctor's Avatar
If I'm reading this right that is pretty much normal, when you bring the slide in, it will rock back first to pick it up out of the tray the edge sits in when extended. As it comes in it will be above your floor level to clear either your carpet or vinl. flooring. 1" sounds a little high I think mine is like 3/4" on both slides when retracted. I doubt removing anything caused the problem.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-29-2016, 02:08 AM   #3
Is the seal area constant on the Outside when the slide is "In"? Did you use fasteners that are "Too Long" and went through the slide floor? Youroo!!
Old 03-29-2016, 02:35 AM   #4
I would think Youroo, that if the fasteners where to long he would he see signs of scarring as it drags over the floor? .... also if the bottom seal is in place with no gaps I think IMO only that it is just the way it looks. If it's to high it could be adjusted down but it has to lift to be brought in. It should be riding on those neoprene blocks that they install at the edge. which are higher then the floor level. At least that is how mine works, I have had nothing but slide issues since my dealer adjusted them, when I kept breaking those cheap glide strips. 3 sets in two years.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-29-2016, 11:31 AM   #5
mike.t's Avatar
This has been discussed before. The general opinion is this is normal.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-29-2016, 01:46 PM   #6
rcla2014's Avatar
What you have described about your slide tilting when you bring it in is normal. It lifts up a little as it reaches its in-most position. Every slide I've seen does that. It makes sure that the seal on the outside is flush with the outside of the trailer and that the slide does not scratch up your floor.
rcla2014 is offline   Reply With Quote
Old 03-29-2016, 10:28 PM   #7
Thank you all for your feedback. Appreciate it.
Old 03-30-2016, 02:01 PM   #8
My Rockwood did that, my Heartland does not. The main problem with it being "normal" is convincing a prospective buyer that it's supposed to be that way.
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
spudston is offline   Reply With Quote
Old 03-30-2016, 03:57 PM   #9
I do not know what system Hartland uses or your system. But if the side doesn't pick up to clear the flooring how does it come in? Yours might not pick up 1" but how will a Hartland bring a slide in over carpet or even lino?....even if yours is on rollers it still has to pick-up to clear the bottom edge when extended and it has to pick up to retract it. What does your do to retract? interesting.!!!!!
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-30-2016, 04:48 PM   #10
mike.t's Avatar
Someone convinced you
2015 Salem 27RKSS
55' Chevy Bel-Air
slide
