Old 06-08-2016, 04:01 PM   #11
There is an Allen screw holding it. It must have come loose and the gear moved. It was preventing me from opening the slide out as it was hitting a bolt that was holding the metal t to the floor. I was able to slip it back towards the center with a long screwdriver and thank goodness I have long arms. The problem now is getting the 2 gears to mate up. I was able to get the slide out so the gear is closer it's just a very short work space and I assume there's a flatspot on the axle for the Allen screw to flatten against. If that's the case lots of trial and error
Sent from my SM-N920T using Tapatalk
jbusch is offline   Reply With Quote
Old 06-08-2016, 04:24 PM   #12
Sagecoachdriver's Avatar
Did the diagram help? So now it's out of sync with the other side?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-08-2016, 04:47 PM   #13
The diagram did help. Talked to the dealer and he said there is roll pins on either side of the gears to keep this from happening. However, the diagram doesn't show that. He said the mechanism is easy to remove and reinstall when the slide is out. Only a couple of bolts. Thankfully I have air tools. It's probably out of sink as only 1 side is driving right now
Old 06-09-2016, 10:29 AM   #14
Jbusch, are your sides still in sync or did this throw it off and cause one side to stick out more than the other when retracted? We have another thread Slide Adjustment - Need your opinion where we are trying to figure out the adjustment. Have you seen anything under there where it can be made, just one cog on the gear?
Old 06-09-2016, 11:00 AM   #15
Head Rambler
That gear is kept from spinning on the shaft by a square key and slotted keyway. If it'll spin on the shaft then the key is missing. You'll need to replace the key and then align the sides of the slide and turn the gear until it will slid onto the key and finally tighten it down.
The roll pins the dealer is talking about are probably the ones on the side of the drive box assembly. They keep the shaft from moving, but not the gear itself.
Gotta go campin!
Old 06-09-2016, 11:09 AM   #16
Right now the aligment seems within specs. However once I pull the mechanism I'm sure I will have to realign it. My plan is to count the number of teeth on the gear as contacts the slide mechanism and hopefully since I'll be pulling the entire mechanism which includes both gears fore and aft the motor and shaft I can realign it.
Old 06-09-2016, 11:56 AM   #17
Head Rambler
Since you're pulling the entire mechanism it shouldn't be much of a problem to get it aligned properly when putting it back.
Gotta go campin!
Old 06-09-2016, 07:57 PM   #18
Ok, maybe im missing something but this entire mechanism looks welded together and therefore no way to take out via bolts. The base plate seems like the only way to get it out but in order to do that I have to lift the slideout Anybody?
Old 06-09-2016, 10:31 PM   #19
Do you see any bolts holding the slide box to the geared rail? I saw none on mine looking from your point of view, just holes with no screws or bolts.
I found them, they did not use the first 2 set of holes to fasten the mechanism to the actual slide out. Found bolts in the third set half way down the track.
Old 06-10-2016, 10:12 AM   #20
Head Rambler
In order to remove the entire mechanism, you're going to have to run the slide most of the way out and jack it up slightly and block it up so you can get the mechanism from under it.
Gotta go campin!
alignment
