Old 06-10-2016, 11:15 AM   #21
I'm back to trying to fix it while it's installed. I think if I remove the upper cam followers on both sides I might be able to get enough play to be able to reseat the gear. It doesn't spin freely so the keeper key is still intact.
Sent from my SM-N920T using Tapatalk
jbusch is offline   Reply With Quote
Old 06-10-2016, 11:46 AM   #22
Sagecoachdriver's Avatar
Have you spoken with Lippert tech support?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-10-2016, 11:52 AM   #23
Not yet. But that's a good idea
Old 06-10-2016, 12:21 PM   #24
Head Rambler
If you can turn the gear to where the set screw is up, you should be able to slide the gear back under the rack and get a hex wrench in the set screw to tighten it.
Gotta go campin!
Old 06-10-2016, 01:36 PM   #25
Here is a diagram of all the components.
Old 06-11-2016, 12:28 PM   #26
Took a closer look at the diagram in my previous and part B the CROSS SHAFT ADAPTER appears to have multiple holes. Not sure if this could be the adjustment for the gaps many of us are having when the slide is in. One thought is if the slide gear is adjusted one or two cogs on the gear to make a tighter fit, it will make the seal on extension loose by that measurement! Something to consider.
Jbusch, I noticed in the diagram of parts, that the gear has a spline part G and there are 2 part J Crown Gear Set Screws. Have you been able to see those and are they accessible?
I'm trying to get as much information on this so I can pass it on to my dealer Monday when I take the MH in. They have new staff and may not be aware of the adjustments.
Old 06-18-2016, 10:05 AM   #27
jbusch, did you get the gear back in place and tightened up? I don't see how you can get in there to access the screw. You did say you had to remove the above floor slides front kick plate right?
alignment
