Old 02-02-2013, 06:10 PM   #1
jsm
Unhappy Georgetown 300FW- Slide out retraction only "inches" its way in
I have a 2011 Georgetown 300FWSNBF-3011-- with one long slide out from the bedroom to the cockpit. The s/o works just fine going out, but for retraction, it only “inches” its way in at first-- requiring multiple presses of the switch-- & then, after the s/o raises to its highest retraction point, it retracts smoothly thereafter with one continuous press of the switch.
jsm is offline   Reply With Quote
Old 03-31-2013, 05:03 PM   #2
leomosley's Avatar
Hi
I have the same unit as you and find that the slide works much better on the initial rise if you give the ramp area a shot of silicone spray occasionally. You can get to this from the underside of the slide outside, or by lifting the carpet flap inside. I also make sure I am plugged into shore power or have the generator running when I am operating the slide. If you do a search on the Georgetown forum, you will see more posts on this issue. Mine seems to work fine.
Cheers
Leo Mosley
2011 Georgetown 300S
leomosley is offline   Reply With Quote
Old 04-01-2013, 12:39 PM   #3
Dallas Texas
TexasBBQ's Avatar
My largest slide did the same even when plugged in. However, my battery was on it's last leg. When I replaced the battery it went in/out smoothly and just as quick as the other two.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
