Old 04-01-2019, 09:33 AM   #1
Grey Wolf 29b Slide Floor Rot Replacement
Last year we bought a 2007 Cherokee Grey Wolf 29b. Everything is in great shape but we wanted to remodel it - paint everything, new flooring, etc. We leave it at family's cabin so it doesn't get towed save for once a year for storage.
While disassembling and removing carpet in the slide, I found the rear outside corner of the slide floor was rotten. Taking out the paneling in the corner, I found the rot seems to extend up about 18". Looking from outside, I am guessing it come in through the Darco where it is worn.
I am trying to find a way to repair this without removing the slide. I have found lots of info (by going the slide removal route), but I am hoping it is possible to do without that. It is about 18" of 2 wall studs and about 2 square feet of floor.
Thoughts with this? Thank you.
2007 Cherokee Grey Wolf 29B - In the midst of a total remodel!
RickRaw is offline   Reply With Quote
Old 04-03-2019, 06:39 AM   #2
Trying to come up with a plan last night, I noticed some damp spots a bit further down the floor. Took out the paneling to have a look - appears the bottom left corner of the window is leaking. The 4 screws that are positioned around the corner radius were rusty as and the wood framing was damp.
I couldn't see any part of the seal missing around the window, except a couple pinholes in the seal here and there. Hard to believe that much water would get through those though. This is becoming less fun every day!
floor, grey wolf, replacement, slide
