Old 01-21-2019, 08:31 PM   #1
Hello ghost in 2008 Georgetown 37
Came home Friday passenger slide was out about 6 inches, unit is plugged into power and winterized. Unit was locked no one in or around any ideas? Used switch and retracted slide not a clue! Power surge? Power loss?
Thanks Tim
Tsmckie is offline   Reply With Quote
Old 01-21-2019, 09:04 PM   #2
Coach
What type of slide do you have?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 01-21-2019, 09:17 PM   #3
bubbles's Avatar
Assuming you have hydraulic slides/levelers here are some possible reasons from a Lippert document for the drift out:
IN THE CLOSED POSITION, ROOM DRIFTS OUT
1. Leaking cylinder seal
2. Fluid bypassing cylinder piston
3. Hose from pump is leaking Tighten fitting or replace hose
4. Air in system After checking all connections, cycle pump
several times in and out
5. Loose mounting bolts Tighten mounting bolts
Old 01-22-2019, 05:52 AM   #4
They are hydraulic, but can't understand why it sat for three months and decided to open up 6 inches on its own!
Old 01-22-2019, 07:25 AM   #5
bubbles's Avatar
I have, on occasion, found my GT 378 bedroom slide extended a couple inches after being stored for sometime. It has not created an issue when on the camping trail. Doesn't always happen just occasionally while stored. I don't consider it an issue with my system.
georgetown
