Old 05-19-2019, 09:42 AM   #1
Help, No Adjustment for Slide Out?
2017 Sunseeker 3170 in serious need of vertical adjustment. I have reviewed just about every blog out there but could not find the answer. Your help is greatly appreciated. See Pics. I could not find any way to adjust the slide. Is it non adjustable? the gear is in place and on the track centered. I did notice it worked it's way off center, but I corrected that.
ID:	204935   Click image for larger version
Name:	seal inside drop.jpg
ID:	204936   Click image for larger version
Name:	motor side adjustment inside.jpg
ID:	204937   Click image for larger version
Name:	no adjustment a.jpg
ID:	204938   Click image for larger version
Name:	no adjustment b.jpg
Name:	outside track no adjustment a.jpg
ID:	204940   Click image for larger version
Name:	track outside no adjustment.jpg
ID:	204941   Click image for larger version
ID:	204942   Click image for larger version
Name:	correct measurement.jpg
ID:	204943   Click image for larger version
mrosenst is offline   Reply With Quote
Old 05-19-2019, 04:03 PM   #2
thank you, but I figured it out. I would have thought the Number 1 MD RV dealership would have noticed and corrected this. Won't be going back there anymore. 2 minute fix!
Old 05-19-2019, 04:56 PM   #3
Sagecoachdriver's Avatar
I have the same slide, whatís the fix?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 05-19-2019, 06:23 PM   #4
the vertical adjustment is actually on the outside of the RV in the storage compartment. When I purchased the RV my salesperson and SERVICE GUY told me it was the manual adjustment. Finally after exhausting all my options I just gave it a try. I loosened the nut and used a 5/8 ratchet to turn the bolt. I was expecting the slide to move out, but instead I noticed it was raising. I moved the slide out a few inches to take the stress off the seal and it moved with ease. The other adjustment for the second track is located in the generator compartment. I followed the same process, however lowered the side just a bit.
After running the slide in and out a few times, I was happy with the outcome. It appeared the slide was tilting inward, so I lowered both ends until they measured the same distance on top and bottom when fully extended (18 inches give or take). Now I just need to repair the gel coat where the bottom of the slide was digging into the side of the RV. Hope this helps!
Old 05-20-2019, 03:03 PM   #5
Garrette's Avatar
I too have a 2014 3170. Thank you for posting thr problem and fix. I have seen those bolts and thought they were the seatbelt anchors. Really good to know their true function. I will check mine for tightness.
Do you have a reason that caused the misalignment?
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 05-20-2019, 03:15 PM   #6
OK, must be these two bolts I found in my compartments under
the slide. Never knew they were there. So raising or lowering both will adjust the tilt, Thanks!
ID:	205015   Click image for larger version
Old 05-22-2019, 07:43 AM   #7
correct, those are the ones. to answer the other question, I assume they were like that from the factory. after adjusting, the decals are not aligned. could care less, I would rather have a properly sealed slide out. I purchased the coach 3 weeks ago, so I can not confirm any of my assumptions. I just do not understand how a dealer, salesperson and service manager could all notice this and not have it properly adjusted before selling it. Just tells me a lot about that dealership. I have been a technician for 20 years after retiring from the military. I suppose my standards are a little higher. Looking forward to my RV life now.
Old 05-22-2019, 08:56 AM   #8
mrosenst, does your slide out move up and down while going in or out, or stay flat? Mine when extending has the the floor moves out first then the top and mid way the whole slide out drops an inch or two until the top fascia hits the wall. Then the floor come up and stops when all the fascia is hitting the wall and is sealed. Same thing coming in, the bottom moves in first and then the top fascia. Half way in the floor tilts in and then the top of the slide hits the wall and as the bottom pulls in it tilts up some. I checked underneath and see nothing loose. Could just be the center of gravity working????
Old 05-22-2019, 09:06 AM   #9
Sagecoach, I am a novice RV owner but pretty tech savvy. I am sure mine does the same. It appears to just let gravity do its thing when expanding and retracting. This is obvious when closing as the top hits the wall first and the bottom gradually tightens. The important this I believe is when fully out, the roof of the slide has a gradual slope out so water does not move toward the coach. . . . as a wise person once told me . . . don't overthink things. you might create a problem that was never there in the first place.
Old 05-22-2019, 11:57 AM   #10
I made the mistake on our first trip to Yosemite and it rained. I didn't have the MH perfectly leveled and that slide tilted slightly in. Yep, it leaked but not a lot. We ended up bringing it in. The bedroom slide on the other side was fine. Trick, make it level!
slide, slide out
