Old 05-16-2016, 03:35 PM   #1
Help with reattaching bed frame to slide wall
Our bed was attached using 4 - 2-1/2" pan head type screws to the slide-out wall, but over time it appears that the bed frame has moved up and down enough to cause the screws for bed frame to no longer be attached.
Iím looking for suggestions on how to reattach it to the slide-out wall. Iím not even sure if at the factory they lined the screws up with any wall studs from what I can see. Stud finder really no help and I've tried taping on the wall but can seem to find anything except on the corners. So maybe there are no studs in the slideout wall to secure the bed frame to.
I've been thinking of using a 4" x 1/2" plywood stip and glue / screw it to the wall and then use some fatter screws to secure the bed frame.
I've attached a couple pics of what the damage looks like.
Thanks in advance for your help.
Name:	Windjammer slider bed attachment holes 2.jpg
ID:	108047   Click image for larger version
Name:	Windjammer slider bed attachment holes 1.jpg
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
cobiker is offline   Reply With Quote
bed, frame, slide
