Old 05-11-2018, 02:12 PM   #1
Hot wheel hubs
The last few trips,our wheel hub on one wheel on our 5th wheel RV, was extremely hot. This trip, just 15 miles, we could smell burning rubber and the hub was too hot to touch. We assume it may be a stuck brake pad. Any ides on this,and how do we fix it?
thegoodlife1 is offline   Reply With Quote
Old 05-11-2018, 02:19 PM   #2
clr
Well I would jack up the unit so the the tire in question is off the ground. Then try and turn the wheel by hand if the brake is sticking it will be very hard to impossible to turn easily. Listen while turning you should be able to hear only a slight dragging sound of the brakes if the brakes are adjusted properly.
If the cause of your problem is not determined by spinning the wheel remove the drum and look at the bearings and the overall condition of the brakes. There could be many other things going on. When you are done looking and have found the cause repack the bearings and replace the grease seal and put the drum and wheel back on the axle.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-11-2018, 02:20 PM   #3
Flybob's Avatar
Stuck brake pad or bad bearings. I would get it checked and repaired before moving it again. Jack it up and spin the wheel it should be obvious what the issue is.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-11-2018, 02:22 PM   #4
You didn't mention your make/model.
If a TT/5th wheel, you are going to need to have the wheel/hub pulled and checked.
While it 'could' be stuck brakes, it could be a bad wheel bearing and more.
You mention brake 'pad'. Did you have the brakes upgraded? Most TT/5th wheel do not come with pads but rather brake shoes.
If you are not familiar with mechanical things, get it to a reputable dealer quickly. If the hub is too hot to touch in 15 miles of movement, something catastrophic is about to happen with that hub!
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 05-11-2018, 05:50 PM   #5
Thank you. Will try this when we get home as we can't do maintenance at this campsite.
Old 05-11-2018, 06:22 PM   #6
DO NOT Move the Unit! Have a Mobile Repair come right There! You risk loosing the entire wheel assembly! I will repeat DO NOT Move! Youroo!!
Old 05-11-2018, 06:30 PM   #7
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 05-11-2018, 06:39 PM   #8
Thurman's Avatar
I'm aware of the "No maintenance" rule at most campsites. But--IF this were my unit and I had a bottle jack with me (which I do) I would be jacking that wheel just off the ground and rotating it as described in other posts.
Thurman is offline   Reply With Quote
Old 05-13-2018, 09:25 AM   #9
We jacked up our RV and the wheel spins freely, so it must be something else. Can research it more when we get home. I was calling them shoes, but yes, we do have brake pads. We have grease at home, so will try taking off the hubs and see if they need maintenance. If it is more than that, we will probably have to take it to the dealership (CW) - groan!!!!
Old 05-13-2018, 09:28 AM   #10
Thanks for the reply, we did jack it up and the wheel spins freely, so on to plan B, though not sure what that is ,as we are not mechanically minded.
Old 05-13-2018, 09:31 AM   #11
We did jack our unit up and the wheel spins freely, so probably will have to take it to the dealership, which unfortunately is CW.
Old 05-13-2018, 09:35 AM   #12
We did jack our unit up and the wheel spins freely. As we are not mechanically minded, we will take it in to the dealership.
Old 05-13-2018, 09:54 AM   #13
This is the most informative thing Info you have posted! Youroo!!
Old 05-13-2018, 09:56 AM   #14
Oaklevel's Avatar
If it is out of warranty you can take it to any trailer repair shop does not have to be CW or an RV only place.
Good Luck.!!!!!!!!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 05-13-2018, 09:58 AM   #15
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Instead of taking the trailer to the dealer (unless it is under warranty) go to a brake/axle shop.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-13-2018, 10:15 AM   #16
If it is overheating that much you stand to loose a lot more than just a wheel and bearing. It could easily catch fire and loose it all! At least have a fire extinguisher and lots of water readily available in your truck.
Let us know how it goes.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 05-13-2018, 11:05 AM   #17
robbiels7's Avatar
When jacked up if you grab the tire from the top and bottom do you have any play in and out or and grinding while spinning the wheel? Most likely a bearing issue.
robbiels7 is offline   Reply With Quote
wheel
