Old 05-13-2012, 08:37 AM   #1
Question how to lube the slide out tracks and seals
i am looking on some advice on how to lube the slide out tracks and seals.
the dealer told me to buy this spray stuff for seals. i also read here that baby powder does the same thing for rubber seals and wont attract dirt?
any other owners what do you use?
also anyone else mount a flat tv? wondering where to put the mount?
was going to use the old t/v cabinet for more storage? any help or advice be helpful> thanks
campfun is offline   Reply With Quote
Old 05-13-2012, 09:07 AM   #2
Triguy's Avatar
Campfun,
This is what I use to lube the slideout mechanism.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-13-2012, 09:30 AM   #3
Triguy's Avatar
By the way, I use their slideout rubber seal treatment for the rubber seals.
Scott
2012 Shamrock 233S
Old 08-15-2013, 03:09 PM   #4
ok so if this stuff stray's on, does it leave a mess or washing afterwards???
roman253 is offline   Reply With Quote
Old 08-26-2013, 08:51 PM   #5
Frequency?
How often do you lubricate the seals? The slide drive gear?
glen1971 is offline   Reply With Quote
Old 08-26-2013, 09:45 PM   #6
amxpress's Avatar
I lube the rubber seals twice a year, minimum. I use the slide lube mentioned on the gears once a year.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 09-05-2013, 08:43 PM   #7
I'd appreciate a little more specific information on my unit. It has three slideouts. Two of them have visible aluminum gear tracks at the top and bottom sides of the slideouts and the third one has only two gear track rails on the bottom of it that go through the frame. I lubed the aluminum gear tracks and the two gear track rails on the bottom. I could see no other ways to lube anything else. Did I do it right? No instructions anywhere that I've seen.
wyoman is offline   Reply With Quote
Old 09-05-2013, 09:31 PM   #8
BurgPath's Avatar
Is that just a dry lube? Silicon maybe?
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 09-05-2013, 09:38 PM   #9
Lube Type
It's the dry lube pictured above. I was surprised to see that it's a dark color. I was expecting white.
Old 09-05-2013, 09:43 PM   #10
BurgPath's Avatar
I have some graphite dry lube, just wondering if I could use that instead of another trip to CW.
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 09-06-2013, 06:26 AM   #11
Campfire Master
Here's a You Tube video about slide seals:
John
AVid is offline   Reply With Quote
Old 09-06-2013, 07:07 AM   #12
QuietTimes's Avatar
Interesting video. I makes sense that the baby powder would prevent sticking. However I wonder if the baby powder will keep the seal maintained properly. I thought they needed something that would keep them soft and moisturized.....
Heather & Jim
2017 Ford F150 4x4 EcoBoost
2013 Rockwood 2703WS
QuietTimes is offline   Reply With Quote
Old 09-06-2013, 07:18 AM   #13
camper1999's Avatar
2011 GMC 2500HD Diesel
Old 09-06-2013, 07:24 AM   #14
Crusader's Avatar
I would think, as soon as you wash the exterior, the baby powder would wash off the seals.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 09-06-2013, 10:00 AM   #15
Campfire Master
I wash my rig just twice a year. It sits in a storage lot all winter long. After each wash I do a roof inspection and also inspect all the caulking around doors and windows. At that time I also re-powder the seals. Even after sitting in the rain and snow all winter, the seals don't stick to the side when first opened.
I figured if it was recommended by Newmar...it was good enough for me.
John
