Old 08-30-2016, 08:04 PM   #1
How to manually bring slide in on 2006 lexington 283gts
I know its going to happen at the worst time so I want to know how to bring the slides in manually if needed and what tools I will need to have on hand.
Owners manual sucks.
ostbob is offline   Reply With Quote
Old 08-30-2016, 08:17 PM   #2
grumpy0374's Avatar
If your 2006 is the same as my 2012 Lexi 283ts...
In the storage compartments below the two front slides...when you open them, look up to the top of the compartment. You should see a protruding hex bolt on a shaft sticking stright down. Those are the manual bolts to bring the slides in/out. Takes a 5/8 inch socket or wrench.
Bedroom is a different problem. Lift the matteress to access the area under the bed. Toward the head of the bed area, you should see the slide mechanism and its attached motor/gearbox. Sticking out the side of the gearbox you should see a hex bolt held onto a shaft with a safety clip (if like my Lexi).
That hex bolt is the manual bolt to bring the slide in/out. Stupid design, as you have to bring the slide in/out while the matteress is up. And when you get it in, there's not enough room to let the matteress down.
I actually think the designers of rv's lay awake at night just thinking up ways to make it almost impossible to work on these things.
It's obvious that the people who design rv's don't own or have never owned one.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 09-13-2016, 08:13 AM   #3
I too have a 2006 283 and can confirm that grumpy's description for the 2012 model is accurate for the 2006 edition. In my unit there is a large sticker that describes the manual slide-out process. The sticker is inside the left hand cupboard door above the sink.
dthomso1 is offline   Reply With Quote
Old 09-13-2016, 12:51 PM   #4
The only thing in the cabinets above the sink is a sticker with all the RV weigh information nothing about the slide out process. If the process is as simple as turning the nut then I'm covered now that I know where they are. But if it is more involved maybe you could tell me info or send me a photo of the instructions.
Bob
lexington, manual, slide
