Old 05-23-2015, 08:31 AM   #1
How to manually extend the slide out?
I have a surveyor 240 rbs and the slide out will not move. We are at a campsite and really need it out. Is there a way to extend the slide out manually?
philscobra is offline   Reply With Quote
Old 05-23-2015, 08:34 AM   #2
Ford Idaho's Avatar
What is going on that the slide does not go out normal?
If it is electric have you check the fuses?
Old 05-23-2015, 08:55 AM   #3
I have checked all the fuses, I can hear the motor or something under the slide out click when I push the button. But nothing happens. I was told there is a manual extender/retracted but I could not find it.
Old 05-23-2015, 10:16 AM   #4
Ford Idaho's Avatar
Where the manual is would depend on the brand and type of slide you have.
Hydraulic or electric.
Old 05-23-2015, 11:21 AM   #5
It is electric, I have spoke the place I purchased it from, and found that I have a ground fault. And to get the slide out out, we can push it if we disconnect the motors. I am leaving it in.
Thanks for your help.
Old 05-23-2015, 12:40 PM   #6
fedexflyer's Avatar
I have a switch to one of my slideouts that is troublesome. Sometimes I have to hold or activate the switch a dozen times to get it to work, but it eventually does every time. I think it works better when hooked to shore power too. If you're hearing the click when you push it, the switch is trying to engage. I just keep trying and it works. Never any trouble getting it in though, which is a blessing. Good luck
USCG Ret
2011 Sportscoach Pathfinder 405FK
2018 Jeep Wrangler Unlimited Rubicon Recon
fedexflyer is offline   Reply With Quote
Old 05-23-2015, 01:29 PM   #7
AKA: 'tiredTeacher
awellis3's Avatar
Yes. Did you get a long crank with a slotted end? If so, that is the slide crank.
Did you get a manual for the trailer and a bunch of booklets and instruction sheets? If so, read the info on how to do this.
If you have no instructions, look for a hole about 1-2 inches in diameter on the side of the trailer opposite the slide. This is where you insert the crank. (Mine is in the wheel skirting.)
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-23-2015, 05:14 PM   #8
Can u send me a text of where the whole is? I have looked but can not see one. Phone # is 828-817-4769
Old 05-23-2015, 10:07 PM   #9
slipf18's Avatar
Locate the electric motor for your slide...you might have to remove a wooden panel to get to it. On the motor drive unit you should see a 5/8" drive nut...the same size as on your rigs stabilizer jacks...might have a cotter pin through it. This is the manual drive nut for the slide...rotate it using an electric drill with the appropriate size socket or your stabilizer drive handle or a suitable wrench...clockwise extend, counter clockwise retract (or vice versa...not quite sure)
2017Winnebago 2500RL, Hobie Odyssey
Aspen 5.7L HEMI V8,Tekonsha P3
Blue Ox 1500 WDH Airlift 1000# bags
Barker 3500 Tongue Jack
DW & a feisty Border Terrier named Painter
slipf18 is offline   Reply With Quote
Old 05-24-2015, 07:58 AM   #10
Wolverine 1945's Avatar
Maybe no help @ this time ?
This is what happen to me,,, Our dinning slid-out on our Sunseeker would not go out last year,,, it would only click,,, even after talking to the factory,,, I was unable to find what was wrong,,, to make a very long story short,,, I found a rag had twisted it self around the shaft that sticks out in the outer storage compartment !!! No more rags or towels in that compartment !!! LOL !!!
Wolverine 1945 is offline   Reply With Quote
manual, slide, slide out
