Old 06-17-2019, 08:05 AM   #1
How to Reach Top Seal on Slide Out?
I was wondering if there were any tips or tricks for putting seal conditioner on the top seal of slide outs that are under slide out toppers?
Even if I had no toppers, I wouldn't be able to reach the top seal to spread the seal conditioner on top of it with a rag.
On a 7 - 8 foot ladder I'm high enough to see what's up there and blow it off if necessary before retracting, but no way can I reach across and clean / condition the seal by hand.
ScenicView is offline   Reply With Quote
Old 06-17-2019, 08:11 AM   #2
007matman's Avatar
Could you use a painters pole? Spray some in a small roller and attach to the end of the pole.
Honestly, I've never done mine along the top.. don't call the camper maintenance cop on me please.. LOL.
007matman is offline   Reply With Quote
Old 06-17-2019, 08:22 AM   #3
jeff64's Avatar
You have to have a long pole. Have seen where some tie old sock to the end, spray heavily with the 303 conditioner and run along the outside and underneath. If you need to, repeat the proceedure from opposite side.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-17-2019, 08:34 AM   #4
From the inside.
Put the slide out, to about 1' of totally out.
Get a step stool or small ladder and from the inside you can wipe the entire seal (inside and outside) by sliding a rag with conditioner through (towards the outside) and along the seal. The seal will lift up enough to get your fingers through.
I've done this on all our R/Vs that have had slides.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 06-17-2019, 09:21 AM   #5
From the inside.
Iím going to give this a shot.
Old 06-17-2019, 12:37 PM   #6
mbbutler's Avatar
From the inside.
Originally Posted by tyler811 View Post
These Goodyear Endurance tires are just about brand new. I bought them about a year ago and they have about 4500-5000 miles on them. You can see how much tread is left compared to the wear bar. Each tire is showing these "cracks". Attachment 204670Attachment 204671Attachment 204672
Yep, this is the correct answer
mbbutler is offline   Reply With Quote
Old 06-17-2019, 01:59 PM   #7
KEN9XL's Avatar
From the inside.
That is a great idea 5picker. Thank you!
I may try that rather than reaching from a ladder with a pole.
Ken & Marie
2017 Heritage Glen 272RL - 34' 4" hitch to bumper (UVW 7294 lbs / hitch 845 lbs)
2016 GMC Sierra 1500 SLE (4wd w/tow pkg) 5.3 litre engine, rear axle ratio 3.42, & 9200 lb tow capacity
KEN9XL is offline   Reply With Quote
Old 06-17-2019, 02:06 PM   #8
Walmart sells a seal spray that has a fold down spray tube and it shoots a staight line pretty far, that's what I use
poppytoymaker is offline   Reply With Quote
Old 06-17-2019, 02:26 PM   #9
LandKKnight's Avatar
From the inside.
Thank you so much for this question and this answer. I was just doing all my seals and could not figure out how to do the top of the slide, so, gonna try this!
Kevin and Linda Knight
2018 Isata 5 30FW 4x4
dog-mobile for Sophie, Roxy, and Kai
Windsurf-mobile for us
LandKKnight is offline   Reply With Quote
Old 06-17-2019, 03:22 PM   #10
JJaxon's Avatar
How often do you do this clean and condition on slide seals? Im new to slide outs and mine is new, so I haven't thought about that, til now.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2018 Carbon 347 toy hauler
JJaxon is offline   Reply With Quote
seal, slide, slide out
