Old 06-01-2019, 10:56 PM   #1
Hydraulic cylinder
I have a 2014 georgetown MH class A.the slides are inoperable. Where is the hydraulic canaster / gear to check levels of fluid. Thanks
Suzie is offline   Reply With Quote
Old 06-02-2019, 03:39 PM   #2
SeaDog's Avatar
You are not giving much information to go on. Does the hydraulic pump run when you hit the switch, are you setting the parking brake, have you checked the fluid level, are you plugged into shore power, have you checked the fuse panel. Let the forum know what steps you have taken so far.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-03-2019, 12:46 PM   #3
Yes to all except checked fluid level. It's on the jacks and they won't retract either. Just looking to see where to check the fluid level. I don't see a window or fluid indicator
Old 06-03-2019, 12:58 PM   #4
The fluid looks to be down about an inch. Would that cause these issues?
Old 06-03-2019, 01:04 PM   #5
bubbles's Avatar
The fluid reservoir is on the end of the pump. The fluid level should be about an inch below top when the jacks and slides are all up/in. You should check the switchblade circuit breaker shown here in the upper left that the switchblade has not tripped. If tripped (exposed) reset by rotating it back underneath its cover.
Old 06-03-2019, 01:11 PM   #6
There is a line on the tank.looks like just below the fill hole. About one quarter from the very top of the tank. The fliud is about an inch below that line. (.approximately one half empty to very top.) Slides are out and it's up on the jacks. Nothing works. Can't put the slides in and the jacks won't work.
Old 06-03-2019, 01:13 PM   #7
bubbles's Avatar
See post #5
Old 06-03-2019, 01:18 PM   #8
Fluid seems fine. Sounds like a 12v power problem. Check all fuses. Also the auto crossover switch between battery and shore power. Can't remember what it's called for MH.
Old 06-03-2019, 01:26 PM   #9
bubbles's Avatar
Georgetown slides come directly off batteries. No kind of crossover in the loop.
Old 06-03-2019, 01:30 PM   #10
Attached picture
hydraulic
