Old 06-22-2018, 10:23 PM   #1
Hydraulic slide info...
We had a situation that I want to share hopefully to save someone else some headaches.
Our rear hydraulic slide would come out about a foot after a few months in storage.
We tested the system for leaks and found none. I finally had the tech put a pressure gauge on both ends of the cylinder. What was happening was since the cylinder is dual action the pressure of retraction holds the slide in after you close things up.
The cylinder was leaking past an internal seal and loosing the pressure necessary to hold the slide closed. We actually found cylinders on both rear slides were leaking past the seals. Fixed under extended warranty but it took us just about a year, on and off, to figure this out.
Lippert has a specific test for this.
Good luck... Hope this helps someone.
Happy travels...
Reason201 is offline   Reply With Quote
Old 06-23-2018, 07:42 AM   #2
SeaDog's Avatar
Glade you figured it out might help others if you list your make and model so if they have that slide they will know what to check.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-25-2018, 12:29 AM   #3
2015 Cardinal 3800fl
hydraulic, slide
