Old 04-25-2019, 12:00 PM   #1
Hydraulic Slide Issue
I ran in to a coupe of issues with the hydraulic system in our 2019 Sandpiper. It started with the system timing out when trying to autolevel. Then I was unable to retract any of the landing gear. It was believed at the time that the trombetta solenoid was bad. I had to return home for tools to manually retract the landing gear. However when I tried to lift the unit to back under it the slides started to push out. Fast forward a week and a tech from Lippert came out to repair the unit. Due to some miscommunication from FR to Lippert he did not have solenoid but was was able to determine it was defecting and to bypass it so I could hook up the truck and pull it home. Since I didn't want to miss a third trip I ordered a new solenoid and the pump now works as intended. I am still having issues with the slide pushing out though. It will automatically level. If I operate the slides from the controls inside they move independently of the leveling gear. I believe there is a valve that is stuck but I am not sure where to start with trying to figure out which one. Does anyone have any suggestions?
2016 Ford F350 Lariat
2019 Sandpiper 372 LOK
2019 Puma 32RBFQ
cstreu1026 is offline   Reply With Quote
hydraulic, slide
