Old 08-06-2013, 04:50 PM   #1
Hydraulic Slide outs and front jacks operate at same time??
Help! I have a Wildcat 5th wheel. When I operate the slide outs, my front jacks move. What can cause this? easy fix? dont see any leaks and when I operate front jacks, slide outs are okay.
bdaughrity is offline   Reply With Quote
Old 08-06-2013, 04:53 PM   #2
rattleNsmoke's Avatar
If I were to take a guess, Id think you have a leaky\sticky hydraulic valve somewhere in the manifold.
rattleNsmoke is offline   Reply With Quote
Old 08-06-2013, 04:58 PM   #3
thanks for replyrattleNsmoke. Would you happen to know if it is that, how much repair could be?
Old 08-06-2013, 05:49 PM   #4
Campfire Master
Are you using the switch that is next to the pump? If you are, that is the emergency backup and it will operate everything at once. Just a thought.
John
AVid is offline   Reply With Quote
Old 08-06-2013, 05:59 PM   #5
thanks for the reply. No, though. I am using the inside slideout switch.
Old 08-06-2013, 06:27 PM   #6
Honestly, I am just tossing out a possible idea. Hydraulic vales do funny things when they do not operate as intended. As far as cost, that should not matter. If I'm right, I'm sure you'll wanna have it repaired regardless.
hydraulic, jacks, slide, slide out
