Old 08-20-2011, 05:20 PM   #1
onequicksportster's Avatar
Hydraulic slide with elec front jacks?
Just wondering why my 5er has hydraulic slide and electric front landing gear?Why wouldn't they be the same. Is there a down fall to either Thanks..
2015 F250 psd CC Sb 4x4
2007 Wildcat 28rks 5'ver
2005 Harley Davidson
2009 Weimaraner "Dog"
onequicksportster is offline   Reply With Quote
Old 08-20-2011, 05:43 PM   #2
my cedar creek is that way. Never had a prolem. Hydraulic cylinders large enough to handle the load up front would be expensive.
Old 08-20-2011, 06:27 PM   #3
onetonford's Avatar
More complicated and expensive valves and speed controls not to mention a larger Hydraulic pump. Some of them do have them most don't. I would only have them if they were the levelup type of system otherwise I happy with the Electric Jacks.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-21-2011, 06:12 AM   #4
Oh I see, Then why wouldn't they make the slide electric? Thanks for the replys..
Old 08-21-2011, 07:24 AM   #5
I wouldn't want hydraulic jacks on a fifth wheel. Any leak or a blown hose would drop the front end right to the ground. As for the slides, I have no idea why they would use a complicated hydraulic system, as the electric ones work just fine.
Old 08-21-2011, 04:20 PM   #6
jimh's Avatar
Hydrolic slides give fewer problems.
jimh is offline   Reply With Quote
Old 08-21-2011, 04:30 PM   #7
Oh I see but seems like it would be alot more expensive if it was to fail. I did notice it brung the slide in quicker than my 8528ress flagstaff, maybe thats a plus too.
Old 08-21-2011, 04:40 PM   #8
Villa Estate 392FLFB
The_Stuff's Avatar
electric jacks so they will hold up and not fail, hydraulic slides so that it works evenly amongst the number of cylinders. just my assumption.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-21-2011, 04:48 PM   #9
jimh's Avatar
I would think they would b more costly to repair. Mine has them and cracked a fitting during the warenty period. Other than that, no problems.
I bought new n early 2002. Would hate to think what one of thosr rams would cost.
Old 08-21-2011, 05:14 PM   #10
These are all great comments, but if you lose your hydraulics could your slide fall out while you were going down the road? Like if you lost pressure?
