Old 06-08-2016, 04:06 PM   #21
Sagecoachdriver's Avatar
Originally Posted by AbdRahim View Post
It seems as if the top horizontal plywood on the slide flexes at the outer edge as it seats against the side gaskets. This, I turn, causes the fascia to bend in at the edges. I removed all of the Brad staples on the rear closet slide and replaced the with four screws, as shown below. The two screws on the ends of the fascia, I tightened while the slide was fully extended. This allows the fascia to relieve some of the tension when it is retracted. My guess is to do a proper job, one would put a thin piece of wood along the center of the fascia, to move it out so that the ends would not need to flex. Of course then you would have to do staining etc. Too much work for me. Hopefully the screws will hold and I have allowed enough room for the not to pullout.
The fascia over the bed was not as bad, so I only added the two end screws. Time will tell.
Attachment 110532
Is the plywood secured tight to the edge of the slide or does it flex?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-08-2016, 04:13 PM   #22
Here's a video of how loose mine is.
Old 06-08-2016, 06:23 PM   #23
Inside Slide-out Fascia about to coming off
It is definitely su cutely attached, but, I am assuming there is flexing in the plywood as well, since when the slide is in there is space between the plywood and fascia, which disappears when the slide is extended.
I cannot seem to play the video on my iPad. ?I will have to check it on a computer later.
AbdRahim is offline   Reply With Quote
Old 06-08-2016, 07:24 PM   #24
Ok, Sagecoachdriver, that looks scary. I did not observe any movement of the vertical fascia. I will look more closely at a later time, but I am sure they are securely attached.
Old 06-08-2016, 10:40 PM   #25
After taking that video this morning, I removed the insert and pulled the fascia and 3 of the 5 square head screws had pulled thru the plywood. I secured the plywood with 5 more screws and re-installed the fascia. Now there is just a little bit of wiggle.
If I recall, on my Schwintek slide-out, the upper fascia had fallen off and you can see in one of the photos that I cut away some of the overlapping vinyl which caused the uneven surface that the fascia was mounted to. I also used screws to secure the upper fascia and one section actually has a bolt, washer and nut securing it. I had to counter sink it so as to reapply the insert. The screws didn't hold.
Old 06-09-2016, 10:30 PM   #26
I was prepared to put a spacer of plywood under the fascia to bring it out a bit. I figured I would hide any gaps with trim. When I went to video the movement today, ?I ran the slide in and out several times and did not see flexing of the fascia. We will see how well it holds up over time.
Btw, if you ever want to bend wood, I believe you have to steam it. Not an easy process.
slide, slide out
