Old 09-29-2013, 07:58 AM   #1
Member since 2013
Interior slide gasket maintenance
Getting ready for a big fall maintenance project on our 2013 V-Lite TT. I'm planning to use Protectall Slide Out Lube and also Protectall Rubber Seal Treatment on the exterior of the slides (unless experienced users advise otherwise), but I'm unsure about treating the interior gasket. I don't want to spray the Protectall Seal Treatment inside, but I guess I could spray it on a rag and wipe the interior gasket.
Is there another product that would be as effective for cleaning/treating the interior gasket?
Mike-n-Sherry is offline   Reply With Quote
Old 10-04-2013, 06:52 PM   #2
Dallas Texas
TexasBBQ's Avatar
I think that stuff is good for inside and out. I sprayed on small sponge one of those $.20 sponges from Walmart and then apply to the gasket.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 10-06-2013, 05:17 PM   #3
Member since 2013
After reading more about the product, that's probably a good idea both inside and out. Looks like overspray can be a problem, and wiping it one with a sponge would avoid that. Definitely worth a try- Thanks!
gas, maintenance, slide
