Old 02-09-2016, 07:42 PM   #1
Is it ok to have the refrigerator in the slide?
Hi! My husband & I preparing for our new life on the road. We have narrowed down our choice of trailers to Forest River brand. We're looking at a new Flagstaff Super Lite 29KSWS but are concerned about the durability of the slide with the refrigerator. We had read on someone's blog that this was a bad engineering idea in their trailer. On one of the threads in this forum, someone mentioned slides had greatly improved over the years. Are we okay with getting a slide with the refrig or should we select another model?
Thanks for helping these newbies!
Gina
ginaf is offline   Reply With Quote
Old 02-09-2016, 07:47 PM   #2
dcheatwood's Avatar
It's in our slide. The only issue we have is it seems harder to to stay cold in hot weather, many believe due to the vent being in the wall and not on top the rv. No issue other than that.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 02-09-2016, 07:57 PM   #3
There's nothing wrong with a camper having a refrigerator in a slide. We have a residential refrigerator in a slide and no problems. Some people find that an RV type refrigerator does not work as well in a slide. Maybe that is what you have heard. RV reefers need good air flow kinda like draft through a chimney. If the opening to the top of the chimney is on the roof, the air flow (draft) is better. A reefer in a slide has the top of the chimney in the side of the slide and doesn't draft as well. That said, some folks put fans behind their reefers to improve the air flow and all is well.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-09-2016, 08:26 PM   #4
Mr. Dan's Avatar
The two prior posts tell it the same way I've heard it.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 02-09-2016, 08:28 PM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
X 2 Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 02-09-2016, 08:47 PM   #6
TURBS's Avatar
Install fans in the outside compartment if you find poor performance in hotter weather.
I'm installed 2 120mm computer fans in mine as soon as it warms up.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-09-2016, 09:04 PM   #7
MCTroy
I like the idea of installing a fan for our refrigerator that is in our slide. Is that easy to do and do you have to take the refrigerator out? We can handle real basic maintenance but aren't the best at most mechanical things....
MCTROY
2015 Windjammer 3029 Diamond Edition
Hemi powered by 2011 Ram, 5.7 gas crew cab
Ohio River Rats and two spoiled dogs
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
Old 02-09-2016, 09:17 PM   #8
TURBS's Avatar
Easy to do.
Mount fans to draw air in from bottom fridge grill to force air up and out the top grill.
No need to remove fridge whatsoever.
I'm mounting two onto the lower fridge grill to pull air in and one on the top grill to draw air out.
There's a black junction box in lower grill area to draw 12v power from, it's also switched 12v power only when fridge is turned on.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-10-2016, 06:05 AM   #9
MCTroy
Sounds good. I will check this out when we open up the unit again. Hurry spring! Only 15 degrees in Ohio today.
2011 Ram 5.7 hemi
Ohio River Rat
Old 02-10-2016, 06:22 AM   #10
KyDan's Avatar
Computer cooling fans are 12v dc and there is normally a 12v dc terminal
strip in the rear of the RV fridge. I added twin fans and a switch so I can
shut them off in cooler weather.
2 fans ordered online should cost under $20. Ebay is your friend!
There has been much discussion and even photos of that being done here.
I don't have a link right off but a search (or a helpful reader) will likely
provide the link.
Also some units are now delivered with a fan in the back from the factory.
Some here have found the Dometic factory fan to be noisy and some say it's
ok. You can ask your dealer or check for yourself after the spring thaw!
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
refrigerator, slide
