Old 04-16-2012, 03:08 PM   #11
Herk7769's Avatar
Maybe a blanket; then the plywood.
HAM CALLSIGN - KC3FFW
Old 04-16-2012, 04:42 PM   #12
grhodes50's Avatar
Not sure what tt you have, but if it's a Prime Time you can walk on the slide out roof. Below is a statement from their web site.
Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels
Slide Out Construction
On a large percentage of Prime Time recreational vehicles, you will find a slide room enhancing the livability and function of the RV. Recognizing that the slide out construction is critical to the long term performance and durability of your RV, ETERNABOND Construction means advanced construction techniques are utilized in the slide rooms, too. All three walls of the slide out are built using our 5-layer, aluminum frame, bonded construction offering lightweight, yet strong construction that also provides excellent insulation and sound deadening properties. A Prime Time RV is unique in that the SLIDE OUT ROOF is aluminum framed and bonded with EPS foam to create a slide out roof strong enough to walk on.
Gary & Trish
2018 Nights Camped - 5
Old 04-16-2012, 04:50 PM   #13
RattVader's Avatar
Yep what he said.The PrimeTime web site actually has a photo of I believe 2 or 3 guys standing on a slideout. Don"t know if it's been doctored,but they seem to think you can! However I don't know what you own and even though I have the 320 RLT,don't think I'll be trying it anytime soon.Just my .02
Steve & Sue
2011 Crusader 320RLT
2008 Dodge Ram 3500 (CTD) DRW 4x4
RattVader is offline   Reply With Quote
Old 04-16-2012, 04:55 PM   #14
grhodes50's Avatar
I have been on both of my slideouts a couple of times while cleaning. Felt as solid as the main roof and haven't had any problems.
Gary & Trish
Old 04-16-2012, 04:55 PM   #15
TURBS's Avatar
Even a 2x8 or 10 across would help
Old 04-16-2012, 08:33 PM   #16
Triguy's Avatar
Prime time aside, it's not the roof and sides on my trailer's slideout that I would be concerned with. The running gear and brackets that support an extended slideout just don't seem to be sturdy enough to support a 200lb person. It would have to be very well supported with braces or jack stands for my comfort.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-16-2012, 08:59 PM   #17
I've been on my slide out several times with no problems. I was on the slide out on my 2003 Cherokee quite a few times also. No issues. I weigh 195 and gaining more everyday
Triguy, if the gear won't support 200 lbs on the slide roof, why would it support 200 lb person standing inside the slide? I don't see the difference. Maybe I'm not thinking along the same lines as you.
Len & Cheri is offline   Reply With Quote
Old 04-16-2012, 09:03 PM   #18
Triguy's Avatar
That's true about people in the trailer, too. Maybe my sense of physics is off right now.
It might be the wine my DW served me tonight
Scott
2012 Shamrock 233S
Old 04-17-2012, 06:25 PM   #19
RattVader's Avatar
Ya know sometimes it's the most obvious things in life that escape us!
Steve & Sue
