Old 06-01-2015, 09:36 PM   #1
Is this normal?
295kbh. When I put the slide in, the top seems to almost fall into place. It comes in normally all the way and then maybe the last 2 inches it just seems to klunk into place. It actually gives the trailer a bit of a shake. Is this normal?
larryo is offline   Reply With Quote
Old 06-03-2015, 06:13 PM   #2
Slide
Slide outs actually seal at the top by using the weight of the slide. The rollers are out near the outside edge of the floor near the slide opening. The slide comes up the ramp and on to the rollers as it enters the main body of the coach. It balances on the line of rollers, till the weight offsets and the inside of the slide drops and the slide seals at the top first and then pulls in at the bottom. If the slide is light it will come in almost all the way before dropping down.
hillsdaletc is offline   Reply With Quote
